Question about Garden
Changed coil still no spark - Garden
    Novelist:
  • 144 Answers
Need to know make model and year of tractor/engine. Probably points or power or maybe even ignition switch.
Posted on Sep 03, 2010
Cylinder misfire coil
These engines have 3 coils and are paired 1 and 4 2 and 5 3 and 6 with a spark noid run to see if the paired cylinder has no spark if so remove coil from module and test the power supply to coil and with a logic probe test the trigger side if blinking with no spark your coil is bad. not blinking replace module.
Apr 17, 2014 | 1994 Buick Park Avenue
Ford Escape 3.0 no power to #4 coil
Need to change the coil. Is likely the problem. Sometimes that means replacing the whole coil pack.
Apr 10, 2014 | 2005 Ford Escape
Not getting spark
check the coil first with a spark plug tester. then go to the leads at your spark plugs if no spark at the coil change it. .if spark found at the coil but not at the leads at the spark plug. then check the distributor cap and the rotor arm clean the contacts then check the plugs smell them of fuel if that is found change the spark plugs.
Dec 21, 2013 | Cars & Trucks
I got code PO 305 on a 2002 Mercury Grand Marquis, what is the spark plug wire part called, is it #5 coil, and should I replace the coil and spark plug and what should the spark plug be gapped at? Thank...
This will have a direct coil over ignition with a coil over each spark plug. The coil is the electrical part over the spark plug. The coil also has a rubber part that is called the boot or spark plug boot. The boots can be purchased separately but the coils will come with new boots.
is it #5 coil,
Have you checked to see if there is any spark coming out of the number 5 coil?
When was the last time the spark plugs where changed? It may be due for all the spark plugs to be changed. The spark plug gap is usually listed on the emissions sticker under the hood. It should be .050 - .056 or very close to that.
May 16, 2011 | 2002 Mercury Grand Marquis
No spark
There's no emergence switch, if there was it would only be for fuel and not spark, there four thing to get spark,
ignition control module, ignition coil, distributor pick up assembly and spark plug wire's check for spark at coil, more then likely it's going to be your distributor pick up assembly, the pick up sit in side your ignition distributor, replace it and it will start, hope this was very helpful.
May 19, 2010 | 1985 Ford F 250
No spark at ignition coil, changed coil, still no spark
have the crank postion sensor replaced. i had the same problem. dealer cost about $600.00
May 08, 2009 | 1998 Jeep Grand Cherokee
No spark on # 5 cylender 1989 cavalier z24
change the control modul. that control voltage to the coils. it sound like it not bleeding off fast enough the control modul is under the coils. befoe changing any part remove ground off battery. befor change any coils u could of swop to see if this is still not firing
Feb 22, 2009 | 1988 Chevrolet Cavalier Z24
No fuel or spark on my 89 chevy k5 blazer
change coil pickup which is in the bottom of the distrubuter
Feb 13, 2009 | 1989 Chevrolet S-10 Blazer
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
