Question about Electrolux Dryers
Electrolux EDC5340 dryer: drum is hard to turn, error code E50. I can hear the motor trying to turn, so it is not a fuse or open circuit. How do I open the dryer to check for mechanical obstruction or failed bearing, etc?
    President:
  • 3,074 Answers
You can take off the front panel, there are screws inside the dryer door,may have two on the bottom corners and then gently pry up on the top corners with a flat tip screwdriver. disconnect the door switch and the panel is off. check to make sure the the belt is centered and you can turn the drum. hope this helped tim
Posted on Sep 03, 2010
Error E50 an electrolux edh3786gdw dryer
E50 is a motor related error on this model...check to be sure the belt and idler pulley are in proper position, make sure a sock or other garment has not fallen into the filter housing and jammed in the blower fan...
Jun 29, 2016 | Electrolux Dryers
SOURCE: E50 what does it mean, Hello & Welcome to FixYa E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok
Hello Baldur Thor, thanks for your inquiry!
From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
Dec 21, 2014 | Electrolux Heating & Cooling
Electrolux front loader E50 error
Hello Friend, thank you for your post!
I see you are receiving an error code E50 on your Electrolux dishwasher. Is it possible that the code is missing characters? Could it possibly be an E50? May I please have your model number? The serial tag, which lists your model number, is typically located on the right side as you open the door. With this information I can further address the issue at hand. In the meantime, I suggest resetting your dishwasher. You can do this by flipping the household circuit breaker off for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display E50. Thank you - Z.
Apr 12, 2014 | Zanussi ZWF1640 Front Load Washer
Electrolux E52 error code Dryer
Hello drew_wedemey -Typically error code E52 indicates that the unit has a faulty motor. If the drum does not turn freely by hand, then I highly suggest contacting a professional to accurately diagnose the following; motor windings, L1 power supply voltage and the motor thermal protector.
Sep 30, 2012 | Electrolux Dryers
Electrolux EDC77550 drum dryer starts normally but stop after running couple of minutes.
If motor runs continuously with power applied, check for short circuit across motor relay (RL2), or L1 applied to motor relay output (J3-1) with cycle stopped. If motor does not start when Start key is pressed, check for open circuit between L1 and motor relay connection (J3-2). If no wiring problems found, replace Main Control Board.
Aug 14, 2012 | Electrolux Dryers
Dryer works for few minutes then stop and E50 error code is appeared
E50 code is for a motor issue or main PCB fault on the motor output side (also called E51 when the triac that is on the main control board normally shorts out due to a faulty motor).
Not easy to diagnose as a diy job, but you need to find out if the drum rotates correctly when fully loaded. Could check this CODE LIST
Hope this helps.
Jul 01, 2011 | Electrolux AEQ8700F Electric Dryer
E50 code dryer stops
Hope this helps.
Error code E50, what does this mean? We select programme, all the lights are on, we press start and E50 appears. What does this mean?
e50 is a motor error code.check the motor brushes are ok and check the insulation on the motor as this will give you an e50 error code.could also be a faulty wiring loom to the motor or a faulty main control pcb
E50 says the motor is overheated, they recomen you let it sit for 30min to clear.
It can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Dec 13, 2010 | Electrolux EW1000i Front Load Washer
A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Jul 24, 2010 | Electrolux Washing Machines
Hi, I have an Electrolux EWF1087 which is flashing an E50 error message. Can you tell me what that error message means? Thanks Gary.
HELLO GARY E50 error is to do with the motor, it can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Jun 05, 2010 | Electrolux EW1200i Front Load Washer /...
Dryers Logo
1,737 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
