Question about Panasonic PV-GS39 Mini DV Digital Camcorder
Fuse location Do you know Panasonic PVGS39? I have the same problem with no light on with Battery or AC adapter line. Where I can locate the Fuse location and where I buy new fuse? Many thanks. JC
  • 95 Answers
Good day JC, these fuses are surface mount fuses so they can not be changed by anyone. If you do change the fuse and there is a fault on the pcb you could make things worse. So i recommend that you take it to a Panasonic dealer or technician who has electronic experience in camera repairs.
Posted on May 30, 2008
We have Panasonic KX-TG6531, 4 handset. One unit is not working and shows on the screen: base no power. We lost a brochure for this phone and don't know how need fix this problem. Would you help us,...
Even though You did not say how old these units are.?.this is a specific battery problem...
you can test it..take the other ones battery and replace problem unit's battery you will see that it will work..You can buy new battery at any Super stores.try to take one with warrant on it..
since you stated that you need an operating manual. pls visit the URL below to download one.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Jul 11, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
The pc not turn on, no power
It might be an issue with the adapter, the battery or the AC jack on the motherboard. First up see if your AC adapter's power LED comes on when plugged into a power source. If it does, then check if the Lights at the front of the laptop indicate that the adpater is plugged in. If they light up then it means that the laptop's battery is faulty and needs to be replaced. If the lights dont light up then it means that the AC adapter jack on the laptop has bad solder joints and/or damaged. It is located at the underside of the motherboard where the AC adapter is plugged in. You will need to take the laptop apart and re-solder/replace the jack.
Let me know if you need more help,
Jan 05, 2010 | Toshiba Satellite A135-S2276 Notebook
Which fuse is for the trailer lights
The aux fuse panel in the engine compartment on the 04-08 has nothing to do with the trailer lights ( that is ABS, clock spring illumination, 4WD and the diode for the AC compressor ).
All the fuses are in the CJB ( aka Central Junction Box, cab fuse panel ):
The trailer parking lamps
Fuse #10 and relay #201
Trailer Stop / turn lamps
R: fuse #36
L: fuse #42
There are a few others with the reversing lamps and the battery charge circuit ( for the 7 pin adapter ).
Bit easier than trying to read each line, is to download a PDF copy from Ford, so you can search on keywords ( in this case trailer )
Dec 26, 2009 | 2005 Ford F-150
Charging indicater light is on but will not power up.
Take out the battery from the laptop and only hook up the ac adaptor and if you get no power to it and still can't turn it on an knowing that your ac adaptor is good, then the motherboard is bad and would need to be replaced.
May 18, 2009 | Computers & Internet
Inspiron 1501 will not power from know good AC adapter.
Hi rogertooley,
I had a similar problem with two SONYs, it turned out on one there was a blown SMD fuse 4A, very near close by the DC power plug.
On the other the Power Management Board was bad and needed a replacement.
If you already went to the trouble of opening the laptop, see if you can locate a SMD fuse and check it. If there is none or if the fuse is ok, then see if you can locate the DC power management board and see if you can find a failed power mos on it.
Jan 10, 2009 | Dell Inspiron 1501 Notebook
Panasonic SDR-H18 connected wrong AC adapter
I accidentally connected wrong ac adapter and to Panasonic dvd camcorder and it will not turn on.....Hopefully this can be corrected??
Nov 25, 2008 | Video Cameras
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    Does hp 1040 fax have a fuse?
    No, is there a geen light on the ac adapter? Is the AC adapter warm to the touch?
    Mar 09, 2008 | HP 1040 Plain Paper Inkjet Fax
    AG 460 panasonic camcorder" FUSE LOCATION"
    just follow the battery and you will see the small fuse color white and have a mark of 3.15 at the bottom of the battery socket..
    Aug 10, 2007 | Panasonic AG-455 Camcorder
    Mini DV camera decided to cease working
    i recently had a similar issue and couldn't locate the power cable for a wall outlet . after trying half the electronics stores in town and multiple universal power adapters , my son left his power cord out for his play station portable (PSP) . my camcorder started up like it was new upon pluging this cord in . hahaha , sorry just looked at the date of entry on this thread . well i hope this info may be of use to someone.
    Oct 03, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
    Panasonic PV-GS39 Mini DV Digital Camcorder Logo
    250 people viewed this question
    Top Panasonic Video Cameras Experts
    Kenneth Walker
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
