Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
LG model LRFC25750WW 25.5 cuft
The fridge keeps shutting off, we have to unplug it to reset the didgital temp. and get it working again .. What would my problem be? The fridge is only 4 to 5 years old. thanks
menoley@cox.net
  • 489 Answers
You may have a problem with the control board and it will need to be replaced.  You will need to have a qualified LG technician to help resolve your issue.
Posted on May 11, 2008
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
My freezer is working but not refrigerator side. Anyway to check
Check freezer fan is working. If mechanical fault,replace fan. If it's struck by frosting behind the freezer, defrost the fridge by unplug the unit. To keep automatic defrost in time, keep temp between 3 and 5 degree. Check timer, thermostat an defrost heater working properly. Turn counter clockwise thermostat, if fridge shuts off, it's o;k. And also check heater with 120 volts directly and working alright or with continuty check if closed it's working. Thanks.
Feb 07, 2011 | Kenmore Refrigerators
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
I have a lucozade sport fridge but it keeps freezing the drinks how can you turn down the temp?
should be a temp setting on the bottom of the fridge, you can also unplug the fridge for 3 seconds and plug it back in this will reset the unit into a normal cooling mode
Oct 03, 2009 | Refrigerators
Fridge stopped working
Sounds as if the unit is stuck in defrost. How old is it? Look for mechanical {twist} timer and turn it until it starts. If it is a newer model unplug unit for 1 minute this might reset control board but you'll have to know if it is either mechanical or Automatic defrost!!
May 27, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Samsung Fridge can't get temp down
it is probably the door switch. I just pulled the switch from a rb2055 and disassembled the switch. one of the contacts is broken.
If you unplug the fridge and plug it back in, the light should work. push in on the switch button with the door open. If the light does not go out, switch is bad.
pry the switch gently out with screwdriver, unplug it and get a replacement.
If you are watching this I can also probably tell you how to jerry-rig it to run while waiting for replacement swicth.
May 05, 2008 | Samsung RB2155SH Bottom Freezer...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
186 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
