I have an HP dv6000 laptop computer 2005 model which when I turn it on the lights on the key board are on but the screen is black. I have already tried taking the battery out holding the power botton for 10 seconds and then putting battery in and turning the power back on and that didn't work. What else can I do, I'm thinking the monitor burned out.
  • 570 Answers
If your display is not coming then try the below steps to resolve it.
  1. Unplug your system to avoid power shocks
  2. Open the cabinet and look for RAM on the mother board.
  3. Take that RAM out of the slot and clean it with "IP".This is a type of chemical and let it dry.If you are not having IP then clean it with an ordinary "Eraser"
  4. Then put it in the slot very carefully.
  5. Plug the power and see that display is there or not ,if not then again turn off the power and take the RAM out
  6. Put it in the other slot and try again.
  7. If you are successful then close the cabinet.
  8. If you are not getting display then try changing Ram.
  9. Also check the on board video card.
Thanks
Have a great day
Posted on Sep 03, 2010
Hp dv6000 laptop screen blurry
Hello Al,
I hate to inform you but the graphics chip in these laptops are known for doing this. HP is aware of that. Every time some one brings me a Hp Dv6000 laptop about 75% of the problem is the system board or overheating issues.
First try cleaning the laptop screen with laptop screen cleaner
Walmart LCD Display Screen Cleaner for TVs Computers and Cameras
if its still blurry connect a external monitor to your laptop to see if the display is blurry on the external monitor (to get to toggle the video from your laptop you will have to press the Fn key + F4)
If its still blurry then its the graphics card or chip needs to be replaced. They are all integrated with the system board / mother board.
If its clear and images are good then the laptop screen will need to be replaced. hope that helps.
Jan 21, 2014 | HP Pavilion dv6000z Notebook
Dv6000 black screen
WOW NO OS STATED why even post?
the black screens of *****, know them well , i do these only.
mostly...
or found on road dead, found this in and attic, or in a dumpster
well it can be any thing right, 3billion transistors and GB of of windows files endless ,to fail. yah or the HDD dead or 1/2 dead.
but windoz is last. always.
first is BIOS, screens,
i presume BIOS never ever shows text or the HP logo
so that means what the CCFL is dead, as most are now this old
dead as a brick the black light see here. see the flash light
trick test, this always test 1, on any of the below listed LT (yours)
http://pcdied.com/monitors.html#Laptop
check out the CCFL Laptop and monitor lest there, hard to get that.
Jul 28, 2017 | HEWLETT-PACKARD HP DV6000 Laptop...
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
A few of the keys on my hp pavilion dv6000 came off today- I reattached them and now my computer screen is blank when I turn it on. The power light is on and you can hear it running but nothing on...
try pressing the function or fn keydown and hold it down then press the the f key that turns off and on the display.Do the key that came off feel the same as the other keys when you push them.it could be that the keyboard is damaged and some keys may not be working as in the monitor key.
Feb 19, 2009 | HP Pavilion dv6000z Notebook
My hp dv6000 monitor wont turn on.
It sounds like a fault in your screen displays, or worse your motherboard. Take it in for a look because the problem is hardware and it needs to be checked and replaced.
Hope This Helps
Nov 20, 2008 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 screen goes blank 5 minutes after startup
i cannot install win xp on my hp pavalion it is already contain win vista and hard disc is SATA type give me a solution
Sep 08, 2008 | HP Pavilion dv4000 Notebook
Problems with my laptop
I think it has to do with your video cardsettings.I suggest u should get knoppix live cd which is downloadable free from the net.You then try to boot your computer using knoppix cd by changing your boot options to booting from cd.You enter the boot options by pressing down one of the function keys depending on your computer make.If u are able to boot in to knoppix you can access your video card and then resety it.
Jul 14, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion DV6000 with Vista
These are well known for VRAM failure and HP extended the warrany for an extra year regarding this model. If they refuse to repair free contact us back..
Jul 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
David Payne
David Payne
