Shows "LE" in display.
Stops, several bleeps then shows "LE" in display, & shuts down, even if machine is VERY lightly loaded. Sometimes works OK with bigger load, sometimes goes part way through, other times, stops during initial filling, sometimes goes right through until final spin. Does not seem to be load related - now. Will repower up after mains removed but sometimes fault shows, other times goes right through with no further problem. Machine is 4 years old but not had heavy useage (once or twice per week).
Problem appears sporadically. Machine fills but drum does not rotate or proceeds as normal until beginning of spin cycle. Water appears to have been pumped out OK. Filter is clean. Machine looks like new, 4 years old, not much used. Problem occurs whether large load, medium or even nothing at all. Looks like it may start, gives a little nudge, strange whining, but not loud noise, maybe from motor, and goes no further. Sometimes it will get into final spin cycle and then start adding water about 3 minutes from finish whilst spinning at high speed. Othertimes it works normal.
  • 135 Answers
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
Posted on May 11, 2008
The led display shows UE and stops
Try redistributing the clothes in the drum and turn it back on. If the load is too out of balance, the machine shuts down.
Dec 20, 2011 | LG WM1812C Front Load Washer
2005/2006 model LG Troon washing machine. Washing cycle ok, spin cycle stops incomplete and LE shows on didgital display.
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | LG Washing Machines
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
Code "LE"
Here is a tip that will help you understand the LE code...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 21, 2010 | LG WM0642H Front Load
Lg washer shows up side down F E code
No, this is not the same as the LE code. The FE code indicates an overflow error or condition. The things to check out would be the drain and the drain line to make sure there are no kinks in it. The drain hose can get clogged with sludge and sometimes a hot wash with a 1/2 cup of vinegar will clean out the sludge. If that doesn't work, I would take a look at the pump to make sure it is not clogged with anything and that the pump impellers are good. Take a flashlight and look into the suction port of the pump. Look for any broken or missing impeller blades. If any are broken or missing or if the impeller will not move freely, the pump would need to be replaced. Hope this helped and best wishes.
Jul 31, 2009 | Washing Machines
Entering stereo code in a VW Golf
Lets go. say the coed was 1234,Press button number 1 untill you got number one on your display.Then press number 2 until it shows on the display .Then press number three untill it shows on the display and the same for number 4.Hold down the last button until you here a bleep then you should be ok.
Jun 03, 2009 | 2001 Volkswagen Golf
Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
LE display
Hi again,
Any developments with the LG washer?
Jul 13, 2008 | LG WM-2277HW Front Load Washer
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
413 people viewed this question
Top Washing Machines Experts
