Question about Cameras
Ge light meter dw-48 - Cameras
Error code He
he error code is a heating error. check the wire connections to the heater, if no problem then you need to check for continuity to the heating element. You'll need a meter to do this. The heater assembly may need replacing. I think they run around $60. We had a Samsung DW for 4 years...finally gave up & replaced with a GE which has been working well.
Jul 11, 2014 | Samsung DMR78AHS Builtin Dishwasher
What is the greatest perimeter that a 48 meter squared rectangle could have?
Infinite.
A one meter by 48 meter rectangle has an area of 48 square meters and a perimeter of 98 meters. A one centimeter by 4800 meter rectangle has the same area and a perimeter of 9600.02 meters. A one millimeter by 48,000 meter rectangle has the same area and a perimeter of 96,000.002 meters. A rectangle one micron by 48,000,000 meters has an area of 48 square meters and a perimeter of 96,000,000.000002 meters. Keep making the rectangle skinnier and skinnier without changing the area, and the perimeter keeps getting longer and longer.
May 01, 2014 | Computers & Internet
What meaning code 48 GE? i just got this code mitsubishi pajero.
Diesel:
48 - GE actuator (in the middle of control sleeve position sensor inoperative) system
48 - lock-up solenoid system (short circuit)
Sep 14, 2013 | 1999 Mitsubishi Montero
GE Monogram 48" Freezer light works randomly
About the only way to determine what is causing the intermittent lighting to your freezer is to do a little electrical testing with a multi-meter. Also to press the door light switch in and wiggle it around may help you locate a bad door switch that simply can be replaced if the light decides to come on only when the door switch is pressed and released a certain way. Click here=> GE_Monogram_Refrigerator_Service_Manual Fresh Food and Freezer Light Diagnostics begin on page 46 of the PDF. I will be here if you have any questions but most of the physical testing will need be done from your end Testing the bulb sockets for firm connections and a good steady 12 volts output and 120 VAC input. If helpful please rate, Thanks, Sea Breeze
Feb 21, 2012 | GE Refrigerators
DW will not drain
If the dishwasher is not completely draining, your dishes probably aren't as clean as they could be either.
Most dishwashers have a filter screen to keep solid food from getting into the pump. This could be stopped up. Also look for kinks in the drain hose.
Aug 21, 2009 | GE 24 in. Profile PDW7880G Built-in...
Flickering light GE 48' side by side refrigerator
i had the same trouble .. in mine there is a plastic cover that slides off with some difficulty (slides toward the front) ... this exposes the light bulb which was simply loose ... its also possible to have a bad bulb but make sure you replace it with the same type and wattage ... observe how the plastic cover came off since its not obvious how it goes back on ..
Aug 05, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Dishes not getting clean, left with gritty residue. Could the filter be backed; if so how do I fix it?
Had the same problem with a GE Nautilus 3400 series.
Solution:
- In their manual, GE recommends not stacking tall dishes on the bottom right tray - this prevents the dishwashing powder from fully dissolving. Are you using the right detergent and rinse-agent ?
If your upper arm is not turning during wash (DW leaves residue on top-shelf items), do the following:
1) Empty the DW.
2) Pull down the rotating arm on the DW ceiling. Thoroughly clean the passageways (I had to tap it on the counter to break-down the sediments).
3) Inspect the mesh-screen filter located on the floor in the back - if it's backed up (ours was backed-up from the inside), you'll need to clean it by removing 4, 1/4" screws holding it to the DW floor and throughly cleaning it (I also unscrewed the plastic valve located on the bottom of the filter compartment). While you're at it, remove the plastic mesh on the DW floor (2 screws) and fish for any objects and sediments blocking the pump.
4) Replace filter and bottom mesh and operate the DW in "Rinse" mode.
5) Press the rotating arm back in and operate the DW in "Rinse" mode. Check rotation.
- Good Luck !
Feb 21, 2009 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus/dw
it sounds like your dw wont drain. check air gap cap on sink, if there. then drain blocks.
Dec 24, 2008 | GE Nautilus 24" Built-in Dishwasher
Refrigerator Problem
HI,
I suggest you to repeat the same process again.If the problem comes back again after 48 hours then start checking your defrost heater and defrost thermostat, you will need a volt/ohm meter.This process will require to remove the back panel to troubleshoot.The best solution is to get this repaired.
Oct 13, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge dw gsd5940
there is a piston nut in the back under that screen,.... check into replacing it.
Dec 04, 2007 | GE 24 in. GSD5940 Built-in Dishwasher
Cameras Logo
131 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
