Question about Philips arcitec 1060 Electric Shaver
Hello After turning off my arcitec Philips shaver the red light in the bottom of the shaver start to blink for many times.Please help me, if you know the solution. Thanks in advance! H.R.
brector3
  • 1600 Answers
SOURCE: I have a norelco arcitec 1050 shaver. I can't
See link below for user manual. Everything you need to know is in the manual.
http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
Posted on Feb 22, 2010
Testimonial: "thanks for the response to my question. the information that was given helped tremendously. "
  • 9 Answers
SOURCE: my philips arcitec 1095 shaver the jet clean
I have had 3 1050CC shavers all with the same problem. Apparently other models have the same issue. After about a year of use, the unit reverses after dipping the shaver into the cleaning solution for a second. Two were replaced by Philips within the 2 year warranty period. I still use the 3rd one. There are several things you can try. If the cleaning solution is low this will cause the shaver to reverse and not clean. Add more cleaning solution. I have noticed that sometimes I have to add more fluid to the unit after a week of use. Sometimes it is necessary to fill the solution a little above the max fill line. Be careful though. Filling it too much above the max fill line can cause cleaning fluid to run out of the bottom after a cleaning cycle. If the above two fixes don't work, then press the clean button and after the unit reverses back up, wait about 5 or 10 minutes and press it again and it should stay down as long as there is enough cleaning solution in the unit. If you wait too long or too little to press the button, it won't work. I have noticed if I press the button immediately after it reverses the same problem occurs. Also if I wait 30 minutes before pressing the button the same problem occurs. There must be some sort of timing cycle. You may have to repeat this process a few times to get it to stay down and clean. This is the only way I can get mine to clean now. Obviously something is getting dirty or wearing out over time in the cleaning system. Since I have had 3 shavers with the same problem, I know many others have had it too. Philips must be aware of the problem. It is frustrating that they don't offer help on their own website and consumers have to band together to solve problems that they should be solving. The two year guarantee is very generous, but there is a design flaw with this product.
Posted on Jan 23, 2011
SOURCE: BLINKING PROBLEM WITH PHILIPS FTR9965
Solved
Replace MP40 and its working perfect
Posted on Jul 23, 2008
  • 138 Answers
SOURCE: philips 42pf7320a/37 dead
I do agree with the tech but if the green led don't come on and the 7-blink error code is still there. check the connector from the logic board that will be the board under the small signal baord. The small signal board have the AV input on it. Check the connector from the logic board to the power supply there should be one connectore btween those 2 boards. On the power supply side second pin from the left it will say Vs_On if the set has 0 volts the proble is the SSB or the logic board. how to determain that is to Use 2 Jumpers to short J8003 & J8004 on the left edge of the PSU (see figure below).
Use 1 Jumper to short CN2012 on the lower left part of the Logic PCB (this will supply a 100% White signal to the Display).
Plug in the AC to the PSU thru CN8001.
If PDP panel operates with White field screen then problem may be the SSB.
Posted on Aug 20, 2008
SOURCE: red light flashing 6 times
I found the above web site pretty helpful, too (AVForums), and have spent a couple of hours reading that thread.
Seems like the capacitators are often why the power won't come on. Also, some people mentioned that holding a blow dryer to your TV will make it come back on. According to the tech-savvy people that could mean that your "solder joins" are cracked. So when they're cold they'll contract and lost the connection,and when you heat them up, they expand and reconnect where they are supposed to. I'm not tech savvy and this doesn't explain much to me, but it's interesting, and I'm sure somebody will go "aaah, I see...."
I'll quote a post from AVForums:
"The main components that wear out are the capacitors which, with aminimum amount of electronics knowledge and a suitable soldering iron(you need one with a tiny point, preferably a butane gas powered one)and a powerful magnifying glass. This must be self supporting or onethat hangs from a neck cord.
The capacitors and any other parts you need can be purchased very, verycheaply from rswww.com and they offer a free delivery service or, foran extra fee, a next day service!
When you remove the back panel from the TV, you will see a few circuitboards and you need to locate the one for the power supply.
On mine it is really obvious as it is situated at the top just left ofmiddle. They all have numbers printed on the circuit board. Mine are2662 (25V 1000 uF) 2663 and 2664 (both 50V 100uF)
The ones originally fitted are '85 deg C' but it is best to replacethem with ones that are '105 deg C' because they will last longer.
These '85 deg C caps' normally have a guaranteed life of of 1000 hours,whereas the '105 deg C' ones have a guaranteed life of 2000 hours!
This being the case, when Philips build the sets they know that theywill probably break down after a minimum of 1000 hours of use. If wesuppose that the caps last for twice their minimum life span (2000hours) and the TV is switched on for an average of 5 hours per day overthe year one, ore more, of them will probably fail in the secondquarter of the second year.
With this knowledge, for high cost items such as this, you would alwaysbe wise to take out an extended warranty and Philips, or any othermanufacturer, should be obliged to include an information card warningconsumers of this fact!
The Aluminium Electrolytic - Radial capacitors in question are,usually, 2 x 100uF. The voltage, I believe, depends on the screen size.My 42" screen requires 50V whereas the 32" version uses 25V caps.
There is also a larger 1000uF capacitor, of a similar type, that willbe sighted close to the other two. This seems to be 25V, whatever thescreen size!
The only thing you must remember when replacing these caps is that thelonger leg on the capacitor is 'Positive' and the shorter one is'Negative' and you must ensure that you do not damage the circuit track!
If you are careful and have a steady hand it is quite an easy job butif you are not too sure, you will probably be able to find a localrepairer that is able do the job.
However, you have to beware of the Companies that offer a service wherethey come and collect the tv for a set fee, usually just under £100!They then work out the cost of the repairs and, if you give them the goahead, they deduct the amount paid from the overall repair cost.
I have looked into many of these and, even if you agree to the repairestimate, usually in the region of £300, they never seem willing toguarantee the repair for longer than three months, six months at thevery most!
When you consider that these components cost a matter of pence you can see the value of trying to repair it yourself."
Posted on Jan 27, 2009
I have a Norelco arcitec 1050 electric razor and I have lost my instructions. What does it mean when the red light starts flashing (picture of razor heads)?
Means that the the replacement heads indicator flashing, it's time to replace new heads. That Norelco RQ10 heads for Norelco arcitec 1050 electric razorreplacement parts.
Aug 15, 2011 | Health & Beauty
I have 3 red lights started today 'what exactly i have to do ? tamir
It's means that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is Norelco RQ10 shaving replacement heads.
Apr 27, 2011 | Philips arcitec 1060 Electric Shaver
The red light showing the shaving head remains on and the shaver discharged the shaver is one year old
Philips suggests changing the heads every 12 months. The indicator is instructing you that it is time to change them. You will find replacements for model 1060x at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Dec 01, 2010 | Philips Arcitec 1060X
What is the red light on the bottom of the arcitec, looks like the shaver head
It's means that to change heads replacement parts. Replacement heads for norelco arcitec is Philips Norelco RQ10 shaving heads.
Sep 05, 2010 | Norelco Health & Beauty
My Phillips arcitec has a red light blinking at the very bottom of my shaver. I've had the shaver for 3 years.
It's means that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is Norelco RQ10 shaving heads.
Aug 05, 2010 | Philips arcitec 1060 Electric Shaver
Red light came on in the form of the heads. Is it time to replace
This means that it is time to change the shaving heads. You will find Arcitec replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Jun 11, 2010 | Norelco Arcitec Electric Shaver -...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
What is the red blinking light showing the head mean?
Hello. That is a reminder that it is time to change the head, to maintain optimum shaving. It will blink the next 7 times you turn on the shaver. Here is the manual if you want to read more about it. http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
ps kindly rate my answer as very helpful. thank you. Joe
Mar 29, 2010 | Norelco Arcitec Electric Shaver -...
Norelco arcitec -when I turn off red indicator light showing shaving heads illuminates - has not happened before - what does it indicate?
It means that it's time to change the heads. You can purchase replacements at shaveroutlet.com. See link below.
Once you replace them, you will need to reset the indicator light. This should be covered in your user manual. If you no longer have your manual, you can view one at the link below
Feb 04, 2010 | Norelco Health & Beauty
Philips arcitec 1060 Electric Shaver Logo
744 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
