Question about Technics SL-1200MK5 Turntable
Distorted sound. The sound is very distorted..I have cleaned(head shells) even changed the needles.They are set at proper weight per MFG standards.BTW the sound is only distorted whene it plays through my stereo which i use as the amp.it sounds fine through my earphones.the stereo(amp) i have used it with no problems until now. anyhelp is welcome thx..
    Problem Solver:
  • 6 Answers
Your turntable is a preamp. Your amplifier might be going bad. did you connect it into phono? dont connect it into the cd or dvd input because those wont work.
Posted on Jun 03, 2008
  • 69 Answers
Does your stereo play your cds fine m8? if so its your rca leads or your phono ports on stereo.if not then your stereo amps fuked.gd luck
Posted on Aug 06, 2009
Maybe try replace the rca cables
Posted on Oct 08, 2008
Sony handycam ccd-tr9 video playback is distorted
sir,
the video head problem, try to clean it with head cleaner cassette. play the cleaner cassette several times, test, if still problem must change the video head.
Jan 20, 2016 | Sony Video Cameras
Despite cleaning and demag my kenwood x-se7 deck still produces a distorted sound, any suggestions why appreciated
It could be a bad relay in the record circuit or work out heads. I would have to look at the unit to tell you more.
Mar 28, 2014 | Audio Players & Recorders
Quiet distorted sound coming from my turntable
If the turntable's cartridge/needle are "magnetic", you need an amplifier with a "PHONO" input. Most new amplifiers do NOT have one, as that stopped when CDs began replacing LPs decades ago. Since the reemergence of LPs, some expensive amps have added a PHONO input again. Only really cheap turntables have CERAMIC cartridge/needles (usually under $100), which work fine with any amplifier input but are of a much lower quality than magnetic. Places like Radio Shack and The Source sell inexpensive Pre-amplifiers for this task of increasing the sound level and correcting the frequency response to RIAA standards. The latest turntable I bought had a Preamplifier built in plus a USB connection for converting LPs to Digital.
Sep 24, 2017 | Audio Players & Recorders
Distorted sound on CD
Sound is distorted when the media is not being read properly, try cleaning the lens, tip : burn the cd's/dvd's at lower speed.
Jul 20, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Distortion on speakers from CDX-M630
sounds like you have a faulty head unit
Sorry
Mark
www.blueice-electronics.co.uk
Nov 23, 2008 | Sony CDX-M630 CD Player
Sony kv 32ts36_speaker sound is distorted
the speakers can only be accessed from the inside of the set. try using the sound Field button on the remote ( the one with the music symbol). change to effects off it may be in surround mode and causing the speaker to buzz.
May 02, 2008 | Televison & Video
Toshiba 32 inch tv picture is distorted
have you tried pic size on the remote to adjust the image. normal is the factor default.
Jan 29, 2008 | Toshiba 32AF43 32" TV
Picture distorted
Hello buddylaw,
Can you post a picture of the TV screen with the problem? It will help in the diagnoses. It looks like you may have a thermal sensitive component causing this issue. But I will have to seen a picture of the screen to properly diagnose this problem as to the possible section that may be causing this problem.
Thank you.
Shuttle83
Sep 10, 2007 | Sony KV-36XBR450 36" TV
Technics SL-1200MK5 Turntable Logo
468 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
