Question about Elna Sewing Machines
Don't know how to thread elnita 120. Need a diagram on how to thread elnita 120 sewing machine
5 Suggested Answers
  • 8 Answers
SOURCE: don;t know how to thread a sewing machine
Check out this site to see if they have the diagram for your machine.
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on Feb 11, 2010
  • 1116 Answers
SOURCE: need threading diagram for model #1766
Go sewusa.com for a free threading diagram.
Posted on Feb 20, 2010
  • 255 Answers
SOURCE: how do you thread an Elnita 140 sewing machine
Hi. Have you checked out my tip on threading sewing machines?
Sewusa has the manual for your machine (http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/110_120_140_Instruction_Manual.htm) and threading diagrams for similar Elnita machines (http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm).
Hope this helps!
Robbie
Posted on Apr 02, 2010
Tally Girl
  • 1122 Answers
SOURCE: I need a manual for an Elnita 120 sewing machine.
you can buy one from www.sewingmanuals.com via paypal. They have this model listed.
Posted on Feb 27, 2011
My Elnita 245i is squeaking when it goes forward, but not in reverse. Ive oiled inside the needle mechanism and bobbin case areas. No change. It is also breaking top thread after 6 inches
If your machine is mechanical (not computerized), it could very well benefit from a good cleaning and oiling, including the internal mechanical movement. Squeaking could be the feed dogs but could be a multitude of places.
When threading the machine, be sure to ALWAYS raise the presser foot. The fact that the top thread is breaking about 6 inches into the sewing indicates that the thread is catching somewhere. Sometimes, it catches on the thread notch on the thread spool. Other possibilities is that the thread is looped around something, ie the spool pin, a thread guide... Remove the thread entirely from the machine and rethread from the beginning.
Elna Elnita 244 245 Sewing Machine Threading Diagram
This may help you if you decide to try to oil your mechanical machine:
Wheel on right side that controls the needle up and down is very tight...
Feb 07, 2017 | Sewing Machines
How do I thread a elnita 200 sewing machine?
Perhaps this will help:
Elna Elnita 225 Sewing Machine Threading Diagram
HINT: Be sure to raise the presser foot BEFORE threading the upper thread. It releases the upper tension disk so the thread will seat properly. Do this every time the upper is threaded.
Jan 06, 2016 | Sewing Machines
Thread an Elnita Top 300 Sewing Machine
I am NOT familiar with your machine, BUT..... many machines have a threading diagram decal on the INSIDE of the head cover on the left [needle] end of the upper body!
Jan 09, 2015 | Sewing Machines
How do i thread an Elnita 120
try sewusa.com for a threading diagram
or try these sites for a manual
sewingpartsonline.com
sew4less.com
sewusa.com also has manuals
sewvacdoctor.com
a1sewingmachines.com
May 02, 2012 | Elna 2007 Mechanical Sewing Machine
I have mislaid the instructions for my Elnita 140. In particular, I need to find the instructions for threading, including the little bobbin that goes underneath!
This is a machine made under licence for Elna back in the 80's I believe. So should be a bobbin inside a bobbin case mounted vertically. Try this link for threading up, it should be very similar.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_225_threading_diagram.htm
Many machines have this bobbin case design and they all work much the same way, you need to place the bobbin into the bobbin case with it turning the right direction, click the thread into the tension spring on the outside of the bobbin case then latch it into the rotary hook of the machine, usually there is a little latch on the bobbin case that holds it in.
Top thread is usually fairly obvious, from the spool through an eyelet, through the take up lever, through a tension device, then down to the needle.
Always thread up with the pressure foot raised as this opens up the tension device and allows the thread to seat in correctly.
You can probably buy a manual for your machine from either sewusa.com or www.sewingpartsonline.com or "sewing machine relics" websites. Or just search ebay, there are several vendors who sell pdf copies of different manuals there.
I hope this helps you get sewing with your Elnita, four thumbs up if so.
Aug 21, 2011 | Sewing Machines
Hello! I'm a beginner at sewing and recently inherited an Elnita 130 sewing machine. Does anyone know how I can find a manual for this? I have searched a number of websites selling sewing machine...
You can check this out. Doesn't list your model, but it is most likely similar to the 120 and 140. Usually, the only difference between one model and the next is one will have a few for stitches or added functions. The basic operation is probably the same:
Elna 110 120 140 Instruction Manual
Elna Sewing Machine Manuals Instruction and Repair Manuals
May 25, 2017 | Elna Sewing Machines
How do you thread an Elnita 140 sewing machine that is really old but can still work?
It's easy! Start from the thread holder at the top and go left - hook it under the hook which is behind the round disc that the bobbin winds around, then forward down thru the tension, then under the straight metal bit that's below and slightly to the left of the tension, then up into the hook (slide it behind and then slide forward into the hook), then back down and flip it into the small hook (which is just under the 'straight metal bit' mentioned above) and thru the needle! :-) Hope that helps. The machine might be an oldie but it's a goodie! cheers Lynda
Apr 02, 2010 | White Sewing 1888 Mechanical Sewing...
Sewing Machines Logo
332 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
