Question about Kodak EasyShare M1073 IS Digital Camera
Lens is out and won't come back in again. Recently put in new battery
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 03, 2010
Honda Accord keeps blowing fuse and won't start
Recently we had to put a new fuse in the starter ???????????? What fuse ? location , size . A fuse blowing means a electrical short to ground .
May 29, 2017 | 1998 Honda Accord
Samsung NX11 Error 00
Low Battery, or exhausted ones, also gaves error 00, due to inability to provide high power to the lens.
Jul 05, 2012 | Samsung NX11 Digital Camera
Sanyo vpc-s1213 12 megapixel, 3x optical zoom lens stuck out, won't turn on
Mine did the same thing after I put in a new sd card. Finally after trying everything else, took out the sd card and it worked.
Apr 10, 2012 | Cameras
Camera is stuck with lens out and won't turn on or
If this camera takes ordinary batteries you may have inserted them the wrong way around.
If it takes a rechargeable pack recharge it for average time recommended and try again.
Sep 20, 2011 | Sony Cameras
Hi I slipped in the garage and dropped the camera when it was on==batteries came out and lens of course didn't fully retract. Put batteries back in and the green light comes on and beeps but won't...
Sorry about your moms camera Terry... but it sounds like it needs the lens replaced. If the lens is stuck out at an angle you can *SNAP* the inner lens section back into place if you're lucky, and it will work again like normal.
I don't know your model, but a refurb lens can usually be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Samsung Cameras
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
Jun 08, 2011 | Nikon D5000 Digital Camera
I have a sony cybershot camera dsc w150 and recently when turning on the camera the lens goes in and out 3-4 times and then a message comes on saying to turn off the camera,but it keeps repeating the...
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Step3: Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
Step 4: Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
Step 5: Dip the swab in the isopropyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
Step 6: Repeat the procedure on the contacts on the camera body.
Step 7: Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
Thank you !!
Aug 04, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Kodak EasyShare M1073 IS Digital Camera Logo
236 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
