Question about Ryobi Snap In Primer Bulb Pump 683974 Blower Trimmer
How do i replace the primer bulb in my Ryobi leaf blower
5 Suggested Answers
  • 148 Answers
SOURCE: Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
Posted on Jul 13, 2009
  • 14 Answers
SOURCE: RYOBI RBL-30MVA 30cc when pressing the primer bulb
The diaphragm in the carb may need to be replaced. Make sure all your fuel lines are fine. On these inexpensive blowers the fuel lines tend to get brittle and crack and fall apart.
Posted on Oct 08, 2009
Testimonial: "thanks, will this be a costly thing to get done? will Ryobi replace the part?"
miket756
  • 2702 Answers
SOURCE: Ryobi Leaf Blower
yes,,,,its a dirty carb jet or a blocked carb jet strip the carb and blow out all the running jets,dont go poking wire into any of the jets to clean them this could bistroy the jet/s
Posted on May 08, 2010
Testimonial: "thanks going to go and clean the carb.thanks for the fast responds"
  • 4 Answers
SOURCE: specifications for ryobi leaf blower I'm
walbro carb parts available on ebay-search walbro carb
Posted on Dec 14, 2010
The little pump for gas does not wok
The primer does not necessarily need to work for the unit to run. It does have a choke to aid cold starts. However it is a good indication of something wrong in the fuel system. A primer bulb that does not return to shape or does so slowly indicates a clogged screen in the carb. Check the fuel filter and fuel lines. Replace the fuel lines if they are stiff or discolored, rebuild the carb and replace primer bulb.
Aug 29, 2014 | Ryobi Garden
Ryobi instruction manuals
Aug 29, 2014 | Ryobi Blower Vac 205mph Leaf Blower Or...
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Fuel leaks bulb not priming.
If you have a leak the bulb will not prime. Over time the either the rubber on the primer bulb gets a pin hole in it requiring bulb replacement or one of the fuel lines cracks and introduces air into the lines. Unless the system is completely sealed the primer bulb will not work. Make sure all of the connections on the fuel lines are tight and correct the system leaks.
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Ryobi Snap In Primer Bulb Pump 683974 ...
Diagram of fuel lines for ryobi 280r leaf blower
The line out of the bottom of the fuel tank goes to the curved brass line coming out of the carburetor and the straight brass line out of the carburetor goes to the short side coming out of the primer bulb. The long side of the primer bulb goes back to the fuel tank.
May 11, 2010 | Garden
Ryobi Leaf Blower
May 08, 2010 | Ryobi Snap In Primer Bulb Pump 683974 ...
RYOBI RBL-30MVA 30cc when pressing the primer bulb to allow petrol thro, nothing happens? and as its not letting the petrol thro, the leaf blower will not start....any suggestions? thanks ben.
Oct 08, 2009 | Ryobi Garden
My prime button broke can i bypass it
No, you cannot bypass it. Even if you could get it to run without the bulb there would be a significant chance of fire and injury. Replacement Ryobi primer bulbs are very common, you can get one just about anywhere...in fact, you can go to Google, put in Ryobi and whatever the model number is of your trimmer and the words primer bulb and you will get plenty of hits for parts companies that carry the replacement bulb.
Sep 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Snap In Primer Bulb Pump 683974  Blower Trimmer Logo
236 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
