Question about Philips Televison & Video
Sanyo dp50747, I am a digital electronics tech, I have repaired about a dozen plasmas and lcd's.. I have replaced the x and y sustain boards but the problem didnt change. It may have had a power surge or lightning. I have checked output voltages on lvps and all seems ok. The tv powers on for about 20 seconds and then powers off. You can see light (snow) on the screen with a faded black and white image barely showing the HDMI input displayed in the upper right corner, but when you try to change inputs before it shuts off all remain the same. So my question is what is next? Also there seems to be several versions of the main logic board and some parts lists shows a logic board for this model that is not in this model to make it even more confusing.. The plasma engine is a samsung.
  • 3 more comments
  • Paul Schuster Sep 03, 2010
    I have this under wrong mfr. it is not a phillips it is a sanyo dp50747
    LVPS: PCB Samsung lj41-05246A, I have checked all voltages and they are ok.. VS 15vdc, VA 57 vdc, 5vdc ok, 5vdc standby ok, 12vdc ok. When I first checked, there were two fuses on the LVPS replacing them restored the voltages'.
    Tuner Board: Sanyo J4DL. PCB402456
    looks the same except my board has a .33 ohm, 7 Watt large ceramic style resistor that is missing in your example and others I have seen.. Resistor ID is R1687 and is mounted vertically next to the blue connector. This connector is not used on my TV. Can I replace with a board as in your example? The rest looks the same, maybe different rev levels?
    Logic board looks the same as in your example: it is a Samsung.
    Since the customer told me it went down during lightning storm, can I assume the most logical board to try next is the tuner board? or what would you replace next.
    Not like the old days when you could actually troubleshoot instead of shot gunning the damn thing. Sort of drives me crazy. eenny meanie mighty mo, it is that one..
    Paul schuster
    What I am calling a tuner board is officially called a digital video board... I cant find the exact replacement because now I see there are many versions of this board.. Everything I have found is missing the 2nd connector from the right top.. the actual part number is 1aa4B10N21300 with an extension NP140TL.
    i have already checked dm... these boards are all missing the 2nd connector that is left to right top... I suppose because they do not match the extension np140tl.. thanks for the diagrams, that is a big help.
  • brian carlson
    brian carlson Nov 26, 2012
    My sanyo Dp50747 does the same thing poers up with dark snow screen ... replace logic board same thing change right side sustain board and still does same thing only thing left is power board or main micropressor board
  • Philips Master
  • 5,807 Answers
Hi
you can check on the link if it looks like similar to yours
http://cgi.ebay.ph/1AA4B10N20000-N4PE-MAIN-UNIT-PCB-SANYO-DP50747-/270592483528
and here is the logic board:
http://www.discount-merchant.com/1104605-DP50747-p/1104605.htm
but can you give more detail on the power supply board
( Samsung ) ?
Posted on Sep 03, 2010
50 sanyo hdtv model dp50747 with a black bar or colored lines about 1 wide down left side of screen. I have checked all the ribbon cables and made sure all were tight and good conection. What next?
Definitely drivers, and may or may not be repairable. Here is what I understand. It depends on how the plasma panel in that set was made. Some panels have the X-drivers on a separate board. Others bond the drivers to the plastic ribbon connected to the panel. If it's a separate board, the board can be replaced. If it's bonded to the ribbon, it's virtually impossible to replace the defective chip.
Dec 28, 2015 | Sanyo DP50747 50 in. Plasma TV
Tv just went off
Sanyo DP50747 has about a gazillian completely different implementations.
Some of them have Samsung boards inside, some have LG boards inside and yet another one has Panasonic boards inside.
Samung sets have known problem with the YSUS sustain being killed by a failing buffer board, the LG ones with the YSUS and ZSUS sustain boards, the Panasonic ones with the power board, which reminds me the previous two also have known issues with the power, but not nearly as common as with the sustain/buffers.
Main board is also known to cause issues in the Panasonic-driven models.
All in all it is essential to know which chassis (model) you have in order to provide any meaningful help.
You can also try searching at www.coppelltvrepair.com/search for various repairs or replacements offerred for DP50747.
Feb 12, 2013 | Sanyo DP50747 50 in. Plasma TV
Ive got a 50 inch sanyo lcd and all of sudden no sound what could this be
Check its speaker. If it is OK, check and replace the audio output board. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 02, 2012 | Sanyo DP50747 50 in. Plasma TV
I have a DP50747 and it powers on only every so often. I have removed the back and saw that there are 8-10 capacitors that are bulging on one of the boards (not the buffer or sustain boards). All fu
Just make sure you install them properly, they are polarized. Also, stick with the microFarad ratings as the original. However you can go up in voltage rating, won't hurt anything. I'm confident that could be your problem.
Aug 30, 2012 | Sanyo DP50747 50 in. Plasma TV
TV Won't display picture.
Hello Check its Z sustain board.
Feb 18, 2012 | Sanyo DP50747 50 in. Plasma TV
No video but audio is fine on Sanyo 42" DP42746 TV
If you unplugged the Ysus board, then you need to replace the Ysus board, or both sustain boards. This is the part: The part is often available on Ebay, or from manufacturer. Look also at Vance baldwin or Partstore. To do a good job the Sustain boards should be tested by a tech , following service manual. It is almost for sure sustain board by the way.
Oct 12, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP50747 Replaced Power Supply still not working
I have same problem. Walmart is selling Sanyo junk You are not alone lots of web chatter about these lasting 2 years or less, Mine lased 19 months, Trash it & buy a different brand. I originally was going to buy a Samsung & now I will.
Sep 22, 2009 | Sanyo DP50747 50 in. Plasma TV
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
Sanyo DP50747 50" Plasma sound but no picture green light is on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 25, 2017 | Sanyo DP50747 50 in. Plasma TV
Televison & Video Logo
1,093 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
