Question about Dometic RGE400 Top Freezer Refrigerator
Dometic problem Dometic refrigerator freezer gets cold but main compartment does not
    Problem Solver:
  • 9 Answers
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
Freezer works but refrigerator doesn't get cold
There is a flapper mechanism in the freezer that directs the flow of cold freezer air into refrig compartment. If it is not working properly and is in the closed position the refrigerator will be much warmer than normal. Also make sure that the evaporator fan in freezer is running - it pushes the air out.
Sep 02, 2015 | Dometic Refrigerators
My dometic refrigerator is not getting cold
disconnect thermistor on back let run if ok replace thermistor if not board or cooling unit
Jan 12, 2013 | Dometic RM2852 Refrigerator
Refrigerator to warm
There should be a dial inside the main compartment of the fridge or possible in the freezer that diverts cold air from the freezer into the main compartment. Simply adjust that dial.
Aug 08, 2012 | Dometic RM2852 Refrigerator
Freezer cold but lower compartment does not cool.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Dometic RM2652 Refrigerator
Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Aug 17, 2009 | Refrigerators
Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Aug 11, 2009 | Dometic RM2652 Refrigerator
Bottom not cooling
the blower is broken or frozen.you need to defrost and clean it.or the air passages are clog.
May 08, 2009 | Dometic RM2620 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
150 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
