Question about Sharp AR 201 Copier
A brod white patch on centre con copy Sharp AR 163
    New Friend:
  • 170 Answers
Check the developer in the developing unit maybe the developer is empty,then also check the charging assembly maybe its pour of toner just try to clean
Posted on Sep 03, 2010
My AR-163 copier is bringing out half copy, it will copy and leave the down part uncoppied, how do i solve that problem
Half copy is never an issue with the toner. If you leave the lid open and make a skyshot copy what does it look like, is the copy all black with a thin white border around it, and do you see the scanner light comming on all the way across? You will want to make sure that your developer is evenly distributed across the magnetic roller. Also try looking into the score tron and check the drum cleaning blade and drum.
Oct 11, 2014 | Sharp AR-163 All-In-One Laser Printer
My sharp AR-163 shows a E1 error. First the E is flickering and after that the 1 is flickering.
you would need to supply the sub-code that is given by pressing the copy button (big green button)
but it seems that one of the boards has an issue, and would most likely need to be replaced
Oct 10, 2014 | Sharp AR 163 Copier
Sharp AR-163 Copier, How to Reset/Solve the error Code U2-40
how to clear red sing on tonal problem for sharp ar 163
Sep 16, 2010 | Sharp AR 163 Copier
SHARP AR-287
Is the code a H5 ? Is it a AR-163 or a AR-287? Is the copier making a load noise when making a copy? Basicly, the code means you are have more then 5 paper jams in the fuser & there is a problem there & the copier is locked up.... It's self saving it self
May 05, 2010 | Sharp AR 163 Copier
Sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
Feb 05, 2010 | Sharp AR 163 Copier
What difernt betwenn ar 5320 and 5320 e
The AR-5320 comes standard with XY Zoom and Dual Page
Copy Mode. The AR-5320E has additional image editing functions (Rotation Copy, Margin Shift, Edge/Centre Erase, and 2-in-1/4-in-1) available with the optional AR-EB7 upgrade and you can uprade the memory for printer with optional AR-SM5 256 Mb
Apr 27, 2009 | Sharp AR-5320 Black and White Copier
On sharp AR-163 I have white lines(text mising)from top to bottom ? It happens even when you print only
if you make a copy and the copy is ok but the print copy is bad . this sounds like you might have the wrong printer driver set up.
all sharp al-ar small copiers u must have the exact driver for coper model you can get them at sharpusa.com under personal copiers
Mar 11, 2009 | Sharp AR 163 Copier
AR-163 problem
Replace the toner cartridge.
Jan 04, 2009 | Sharp AL2040CS Digital Laser Copier,...
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Sharp AR 201 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
