Question about GE Televison & Video
The word volume is staying on the screen and the volume will not stay on. when i go to the start menu it just goes crazy, seems anything i have to use the volume arrows for are not working.
  • 901 Answers
Is it working OK with remote control?
If the problem noticed when you use the front panel buttons, you
have to replace all the tiny switches at a stretch.
Due to contact problem the resistance will vary time to time.
Hence you will get crazy functions. better replace all the button
switches of this type. These are all interlinked.
Posted on Sep 03, 2010
I have a Lg LED tv model 47LN5750 that turns on but then stays on the LG "lifes good" screen and will not do anything more. what could be wrong?
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 13, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Volume controll is going nuts.
Hi Manuel
I suppose the problem of your unit is memory, sometimes this problem can be fix by applying service mode, but if not, then memory should be replace and I would advise you to send your unit to service center.
Jan 16, 2014 | Televison & Video
Volume control
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Sep 01, 2017 | Mitsubishi WD-82737 82" DLP TV
My Hp w1907 is doing crazy things. First of all it won't stay on. I have to keep turning it on and off to get the screen to stay on, and now the menu keeps poping up and doing things like turning the...
Aww ****. I thought this had a solution but it didnt. Almost the same thing is happening to me. besides the menu thing. It keeps turning on and off. and this is right after my warranty ran out. I think HP is trying to **** us .-.
Sep 17, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
I have a dell studio 1537 volume indicator stays on screen
Try system restoring it by going to the date that it worked. Just type it in the search box on your start menu and go to it and follow directions.
Nov 19, 2009 | Dell Studio 1537 Laptop
TV stays at the "Please Wait" screen
There is something in the system control not being satified. Probably needs a main PCB.
Oct 13, 2009 | Sharp LC-26D40U 26 in. LCD HDTV
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
No sound and sound menu stays muted so cant adjust
Have you totally unplugged the TV?
If not do so for 10 minutes and see if it resets.
Try to find a remote that goes with TV>
Mastersage.
P.s. Make sure you do not have the saftey lock on. You can adjust the control;s from built in adjustments.
Mastersage!
Feb 14, 2009 | JVC AV-48P575 48" Rear Projection...
Sounds like one of the front panel buttons is stuck in - possibly the volume down button. If no buttons work, this could be the reason why. Just a guess. If they all feel OK, it may still be worth pulling the back off, (Without electricuting yourself -DISCONNECT POWER!) remove the PCB board that has the buttons on it, and see if it turns on without the menu. If so, check all buttons, rare but I have seen one that looked fine but with a multimeter it showed it wasnt working. If the screen still displays the menu, Id say there is a bigger problem... HTH
Jan 19, 2009 | HP f2105 21" LCD Monitor
Televison & Video Logo
79 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
