Question about Whirlpool Refrigerators
Have a Whirlpool top-freezer model ET19TKXL ... the past few days neither the freezer or refrigerator have been very cold, but it acts like it is trying to function. Have adjusted the controls and such to no avail. It seems as though the refrigerant part is ok but maybe something wrong with the fan that actually does the blowing of the cold air? There is a panel at the rear bottom -- is the fan accessed here, and how can I check it? If it is the fan/blower, could a good cleaning of any dust plus some lubrication fix it without having to get a new one? What are some other things I could try, since I live in the sticks and don't have much access to or money for new parts?
SOURCE: New Refrigerator Past Warantee Not staying cold
Thanks - according to the inside of the refrig - I do have a 5-year seal warrantee and a 1 year refrig warrantee - thanks for the tip. No noise coming from freezer or refrig.
Posted on Nov 26, 2007
mikedurland
  • 481 Answers
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
  • 18 Answers
SOURCE: Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
Posted on May 29, 2009
  • 35 Answers
SOURCE: Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Posted on Jul 17, 2009
SOURCE: have an amana refrigerator model BC121VW bottem freezer
In the back of the refrigerator, there should be a vent. Put your hand over it and see if air is coming out. This will tell you if the fan the other poster mentioned is working. If no air is moving then either the fan is bad or the channel is plugged. If only a small amount of air is moving through, open the freezer door and check the air flow again. If the flow got much better, then the return channel is plugged. Try these steps, and if they help post back and I will tell you what to do next.
Posted on Aug 11, 2009
Got my top freezer Whirlpool in Oct. 2008 9.7 cu. ft This past month the refrigerator is not getting cold enough. Milk spoils in three days. Any idea what the problem could be?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Whirlpool Refrigerators
My Estate by Whirlpool freezer coils freeze up and both the freezer and lower compartments won't stay cold. I can manually thaw the freezer and it works ok for a few days then does it again
You have a problem with the automatic defrost cycle, it is typically the defrost control, which is located in the compartment next to the thermostat or cold control. If you send me your entire model number from the tag on the inside I can get you the part number needed.
Jun 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ER8AHKXRSO - STAINLESS STEEL
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
The other thing that can cause this is the heating element going bad, but this is not usually the problem. The element can be checked with an OHM meter. If the coil does not have any resistance then it is bad.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 21, 2009 | Whirlpool ER8AHKXRS Stainless Steel Top...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
296 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
