Question about Fossil Metal Chronograph Silver Dial FS4250 Watch for Men
RE: Fossil FS 4250 Reseting the chronograph, the minute had indicator does not reset to zero (60). It resets at 1 minute. I am able to reset the chronograph second hand and watch second hand, but not the chronograph minute hand. Instruction manual states "If the stop watch hands function improperly, pull out the crown and press A and B at the same time for over 2 seconds. When the buttons are released, the stopwatch second and 1/10th second hands will spin around and return to "0". This will indicate that the internal circuit has been reset." Pushing A and B do NOT cause spinning or resetting of these items. Do you have any suggestions or an "e-manual" for this watch? Thanks, Jim
SOURCE: Second Hand
smash it with a hammer
Posted on Feb 10, 2008
SOURCE: Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Posted on Feb 22, 2008
SOURCE: Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
Posted on Mar 24, 2009
SOURCE: Rolex Daytona 116520 will not start
no! you have not done anything wrong my suggestion is bring it to an authorized rolex service center or any certifide rolex watch fixers.to avoid any damage of your rolex daytona. it mabe costly but you have made it wisely.
Posted on Mar 20, 2008
  • 3 Answers
SOURCE: the watch stops instead of the chrono
On this type of watch the second should not be working unless you are in the chrono mode. The lower dial should be the only indication of the seconds when not in chrono mode. You probably need to have the chrono reset and shown how the functions work. Try a Fossil location they will be able to tell you how to work this watch. It does not sound like this is a major problem.
Posted on Apr 06, 2008
How do i set the month on my fs-4250
Google (fossil)(Fs-4250)(manual) without parens for month setting instructions.
Sep 14, 2014 | Fossil Arkitekt watch
Reset fossil mens es3380
Google (fossil)(ES3380)(manual) without parens for instructions.
Feb 16, 2014 | Fossil ES Watches
Jorg Gray 6500 Chronograph's minute chronograph won't reset to 60 (the default it should be) when I reset it, and according to the manual. Is there a fix for this?
I have got the same problem as Andyxwchow. I already tried too many ways but it still doesn't work. T_T
I really want to know how to set minute counter back to 60
Jul 16, 2012 | Watches
How to set clock
THE WATCH IS SET OUT AS TOP LEFT BUTTON = B
BOTTOM LEFT BUTTON = A
TOP RIGHT BUTTON = C
BOTTOM RIGHT BUTTON = D
10 Half Digit Digital FL145, FL186
Normal Time Display
1. Press A to change mode.
2. Press B for EL.
3. Press C to toggle 12/24 hour format.
4. Press D to stop alarm sound.
Time/Calendar Setting
1. From normal time display, press A three times to enter setting mode. Seconds will begin flashing.
2. Press C to reset seconds to zero.
3. Press D to set and advance to next setting value.
4. Press C to increase digit; press and hold C for fast advance. Press D to set each setting value.
5. Setting sequence is: seconds, hour, minutes, month, date, day of week.
6. Press A to exit setting mode.
Alarm Setting
1. Press A to change to alarm mode (AL).
2. Press and hold C for alarm sound testing.
3. Press C to toggle alarm/chime on/off.
4. Press D to enter setting mode; hour will begin flashing.
5. Press C to advance digit; press and hold C for fast advance.
6. Press D to set hour and minutes.
7. Setting will automatically exit setting mode mode after minutes are set.
Chronograph Mode
1. Press A to change to chronograph mode (ST).
2. Press C to start/stop chronograph.
3. Press D to reset chronograph when it is not running.
Split Time
1. Press D while the chronograph is running.
2. Press D again to return to the chronograph.
3. Press C to finalize timing.
4. Press D to reset to zero.
Mar 29, 2012 | Fossil Fuel Josh JR9120 Watch
Reset chronograph
Hi, I had the same problem and was able to fix it by reading the manual:
Basic Settings for the chronograph hand -
After changing the battery, or in exceptional circumstances, following incorrect operation, it is necessary to reset the Chrono indicator to zero (starting time).
- Leave the winder in Position 1 (pushed all the way in)
- Press button H (top) and button I (bottom) at the same time
- Now set the 30 minute (small hand) counter to zero by pressing/holding button I (bottom button)
- You can now set the 60 second counter to zero by pressing/holding button H (top button).
This worked for me... it took me a while to figure it out, but that
Jun 04, 2010 | Maurice Lacroix Masterpiece Flyback...
Fossil Chronograph--need to know what the two buttons on the side do
Two push buttons is for chronograph function. When you push the upper button - chronograph starts, second push on same button - stops the chronograph. Push on lower button - chronograph resets to zero. Rate me, plz.
Feb 03, 2010 | Watches
HOW TO WORK THE SUB DIALS
This is an Architect Chronograph. To start the chronograph press the top start button. To stop it press it again. To reset it press the reset or bottom button. The sub dials are minutes, hours, and seconds.
May 03, 2009 | Fossil Arkitekt watch
Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
Dec 25, 2008 | Fossil CH2470 Watch
Oct 01, 2008 | Watches
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Fossil Metal Chronograph Silver Dial FS4250 Watch for Men Logo
806 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
