Question about Splendide 2000S Vented Washer/Dryer
Leaking lint filter
Lower lint filter leaks, where can I get a new gasket. We are presently in northern CA. and local supliers can't seem to help.
honestjohn_1
I had the same problem. I cut a new gasket from a piece if old tire inner-tube and glued it in. It seems to work at the moment.
Lewey
Posted on May 11, 2008
How to change gasket on oil cooler 2001 Kia Sportage?
An "O" ring can be purchased at your local auto parts along with your oil filter. Your oil filter screws on top of your oil cooler. Mine leaked as well. A new "O" ring and filter screwed on tightly solved my problem.
Jun 22, 2014 | 2001 Kia Sportage
Just reconnected pump and filter, pump seems to be getting air from somewhere and the backwash continues to leak...any help out there?
make sure the lid is not cracked, and it has a good o-ring, use magic lube for lubing o-ring and threads. you can use electrical tape to wrap around fittings to find suction leak. there is a gasket kit for your bw valve once again magic lube works great for this
Nov 06, 2011 | Sta Rite 1 HP StaRite Pump 15" inout...
Water leaks on floor from my p25 washer.
This is a common problem with Malber. On the lower right hand corner, there's a door with a lint filter. This filter needs to be cleaned on a regular basis. Be careful when removing the filter. It has a large rubber gasket that expands when it's installed and tightened and will offer some resistance when removing. When the filter becomes clogged, water backs up and forces it's way out through the filter.
Aug 31, 2011 | Malber P25 Front Load Washer
Losing antifreeze changed thermostat and resivoir cap
Check you oil for signs of coolant contamination. If coolant is present in the oil, you may have a leaking head gasket or intake manifold gasket. If there is no sign of coolant in the oil, the antifreeze could be leaking past the intake gaskets and into the combustion chamber. It could also be a leak that only shows up when the engine is running, and you are losing the coolant as you drive. This kind of leak is very difficult to locate. You will have to look for signs of antifreeze around the upper and lower intake gasket area with a strong flashlight. Also check for signs of leakage at the upper and lower radiator hose connections and the drain valve at the bottom of the radiator. If you smell antifreeze inside the car, check the carpet for dampness caused by a heater core leak. Sounds like a lot of work, but these mystery leaks as I like to call them, can take repeated inspections before you finally locate them. I hope I have been of some help. Good luck and let me know what you find.
Feb 22, 2011 | 2002 Oldsmobile Intrigue
Oil is leaking from my car's oil filter
are you sure thats the right filter and also remove the cap cover and make sure the new oring is not broken if it is buy another filter and try again, heres a picture of the right filter and orings.fdc1dce.jpgbc9dadb.jpg
Jan 26, 2010 | 2005 Mazda 3
HAVE A OIL LEAK COMING FROM ABOVE THE OIL FILTER.
Has the oil filter just been replaced? Sometimes the old gasket sticks to the mounting area, causing leakage if the new filter is installed on top of it. It is also possible the gasket was for some reason missing on a new filter. Let me know if this is not the cause, I'll try to help further.
Dec 16, 2009 | 1991 Honda Accord
1995 3.8 oil leak at oil filter area still leaks
have you checked the pcv valve and hose to see if motor vacuum is venting the pressure if not press. will build - could be causing your gasket leak problem?
Sep 27, 2009 | 1995 Buick LeSabre
1994 camry oil leak
Hi Toyota Ed
The silver plate seems to be a blank as there are no oil pipes running into.
The leak seems to be weeping along a secondary sump if that makes sense.
If looking from the bottom you have a black sump that bolts onto a silver alloy cast that then seems to be bolted to the lower engine block this seems to have a flexi seal of sealant ( can feel it where it has seeped out) this is were i think the leak is comming from.
Especially when you stop the motor you can see it seeping out around here, but as you know oil sometimes can travel in weird ways and i will check again around the blank plate that you mentioned.
Would i be able to repair it if it is the main sump/ gasket and do you have to remove the motor?
Nov 07, 2008 | 1994 Toyota Camry
Splendide 2000S Vented Washer/Dryer Logo
80 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
