Question about Pioneer PRO-710HD 64" Rear Projection Television
Power Supply repair
I believe i have the same problem as others on your list. my power cuts off intermittently and can turn back on after being off for awhile. How do I send the power supply to you for soldering repair? Any special instructions for removing the power supply? Thank you
  • htsai14752 Jun 19, 2008
    I have the same problem. Now my tv doesn't work at all. What should I do
    Scholar:
  • 90 Answers
SHUT YOUR UNIT DOWN NOW.  We don't want further and more expensive repairs to be needed because of the threat of the domino effect to boards downline from this one, that not remedying this situation carries with it, every moment it has warmed up and is running, in this intermittent condition.
This is a problem that is very widespread on this series of unit, and I have been 100% successful in remedying it so far, both on location and by doing the repair op on boards sent to me from many parts of the continent, and returned by me ready to go.  This has been happening over and over and over again - many Pioneer Elite - and non-Elite - boards have been sent my way, with owners totally blitzed to have their sets up and running faithfully again, after the repair.
Please call me for details and leave me contact info for you, and also send me a request via email, at bob at imageperfection dot com.
I am not at home and can't reach for that stuff to email you, which I can do later once I'm home again later today.
Bob 510-278-4247
Posted on May 11, 2008
My dmtech tv/dvd flashes on the power button when I plug the power adapter into the tv. Sometimes it turns on other times it just flashes. Please help
You have an intermittent situation, the bane of all DIYers and normal repair people. Till it goes completely you might just want to check out the power supply of unit.
Nov 22, 2015 | Televison & Video
Insignia LCD TV loses power
Probably it is a faulty power board.
Oct 06, 2008 | Insignia 37" LCD Flat-Panel HDTV
The local municipal power supply cut on and off intermittently and several times browned out over the last week. the PC could only be restarted after unplugging for a while. Often this had to be repeated...
sometimes in side the power supply over time the parts go bad a little at a time. it will work as lone as you leave it on but if you turn in off the switch mode power supply will not restart due to the parts that go bad. replace the power supply and it should be ok. there could be other things but this is the most likely.
Dec 31, 2010 | Acer AX1200-U1520A PC Desktop
GREEN LIGHT IN BACK OF TOWER COMES ON. BUT POWER TO THE TOWER AND FANS DONT CUT ON.. WHATS THE PROBLEM
The power supply generates 3 different voltages for the system. The most common cause of the symptom you are describing is a loss of the 5V supply line. This is an internal failure of the power supply that sometimes can be easily fixed, but the cost of repair is likelt to be higher than a replacement supply. A typical power supply will cost around $40. If you have another system around, swap the power supplies between the two. If the system now appears to work, you have confirmed the problem.
Dan
May 05, 2010 | HP Pavilion A730N (PJ510AA) PC Desktop
Intermittently turns off on start up and won't
one second of picture normally is the invertor board which controls the back lighting of tv ,but u should get sound with that fault/if not its a faulty power supply/cheapest repair google {ohm supplies} email andy 3 day turnaround tell him john told you to email him normally 50 quid/if not repair shop in rutherglen down lane 150 quid
Nov 10, 2009 | Televison & Video
TV CUTTING OFF ON ITS OWN.
your problem is intermittent if you are not a tech have some one repair your tv the problem could be in your power supply,or horizontal circuit where the high voltage is.it can also be your micro processor. good luck.
Aug 13, 2008 | Philips Magnavox 27MS343S 27" TV
Insignia IS-LCD TV 26 Will not turn on
The power supply will need to be replace or repair if the LCD failed to switch to the blue light.
I repair these power supplies.
Let me know if you need further assistance.
Jun 12, 2008 | Insignia LCDTV26 26 in. Television
50" Mitsubushi Projection TV --- 12yrs old
your tv needs to be repair hitting on the tv signifies that your tv has an intermittent problem.this means that the circuit board has loose connections resolder your circuit board.if you cannot do it your self have a tech look at your tv to repair it.the repairs will not be expensive.i believe that some parts will have to be replace in the power supply prepare for that.good luck
Aug 04, 2007 | Mitsubishi VS-55707 TV
Power light on, unit will not turn on with push button
When power was intermittant, were there any other discrepencies or audible power deprivation to the speakers? Your problem has many possibilites from fuses to major amplifier problems to common power supply failures. Being intermittant then dead may still be a simple fix, but not without some physical intervention of test gear. Sorry, Jaszy
May 30, 2007 | Onkyo TX-DS777
Crazy turn offs
Symptom: Intermittent won't start, power supply LED's may be intermittent Cause: Power supply regulator I901 P/N CZ00868 is leaky, may verify the problem by freezing I901.
Nov 27, 2006 | Hitachi 60V500 60" Rear Projection...
Pioneer PRO-710HD 64" Rear Projection Television Logo
278 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
