Question about Uniden Lands Phones
Arcademeats@bigpond.com.au when phone rings and you answer you can't hear person on the oither end.If you pull out the power cord and replace it works for a few days then goes back the same. Barbara
  • arcademeats Sep 09, 2010
    i don't know where you got the bad feedback from bit I didn't answer at all
    sorry
    thank you have alredy tried deregistering will try second opoption now
    Barbara
  • 1,188 Answers
Okay, you need to deregister and then re-register the handsets. Follow these instructions:
Take the phone out of the cradle (charger). Press and hold simultaneously for more than 5 seconds the red telephone-symbol key and the # key.
You will hear a confirmation tone and DEREGISTRATION COMPLETE appears.
Now go to the OTHER phone (the MAIN phone). Take it out of its cradle and put the deregistered second handset in the MAIN cradle (for 10 seconds). The window displays a few messages and then it will say REGISTRATION COMPLETE.
This should fix the issue. If not, try a full eeprom reset. These are the steps:
Remove battery cover and unplug battery. While holding down the * and # keys, plug in battery, then let the keys go. Now press the top right 3rd soft key below the LCD display selecting reset eeprom. Place in base and re-register (about 10 seconds). If you get 'Registration Failed' then press the red END button and # together until it says 'Registered'.
If both of these fail, you need to have the phone serviced or swapped out for warranty so contact Uniden.
Hope all goes well, this usually straightens everything out. Let me know how it goes.
Good Luck!!
EJ Kudelka
Posted on Sep 03, 2010
  • Uniden Master
  • 19,396 Answers
Hi Barbara.
Line problems of this kind usually are due to a defective phone cable.
If after replacing the cable you keep getting the problem, and this repeats several times, that means that ther could be an incorrect phone line voltage on the phone lines.
I think phone line voltage in Au is about 40V/50V from excchange, going to 70 when ringing, thanks to a ring capacitor discharging. At least this are the values in UK, things in AU are more or less the same.This voltage is brought down by a 470KOhms resistor. If the resistor is shorted, the voltage will keep damaging the cable.
Call the phone company and report the problem.
If this solution helped, please do not forget to accept.
Regards.
Ginko.
  • Ginko
    Ginko Sep 03, 2010
    Hi.
    I see that the question had been passed to a different expert. I expected a clarification request, or a positive feedback after reading volts or calling company....instead I get a bad feedback!
    Goodbye and good luck with your problem.
    Ginko.
I need password for whaikuratuhaka@bigpond.com thank you
you must be real kiwi crossbreed... what is preventing you from calling bigpond and retrieve your e-mail address and password?
https://www.telstra.com.au/contact-us
or call them - phone will be on your bill:
133 933
they answer on this phone number 24/7
Jan 15, 2015 | Computers & Internet
The phone will not ring but when you call the extension you can hear the person on the other end
With the handset on the phone press teh volume up button, that is setting the ring volume. Is it possible that the ring volume is all the way down?
Nov 13, 2013 | Avaya 700340193 Corded Phone
My phone rings but it will not answer i can't hear the person on the other end
If the other person can hear you, then the problem is with the earpiece on the phone. The phone rings using another speaker on the base unit. Swap the mic/earpiece handset unit with another phone and use with existing base unit, to narrow down the fault.
Jan 15, 2011 | Emerson EMSEM2646WH Phone
K800I problem. phone rings but can not hear recipient.
Hi! I think your phone`s microphone is broken, or the software had crashed. In both cases you need to go to a service. Anyway, these are cheap to repair. If you have a data cable try to update your software using the soft that Sony Ericsson provided with your phone or data cable, or download it from here: http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite
Nov 28, 2009 | Sony Ericsson K800i Cellular Phone
The phone rings,states the number calling but you can't talk to the caller. When you answer the phone, the person on the other end can hear you, but you can't hear anything. You can't get a dial tone when...
The switch that the handpiece activates is not working. Could be optical, magnetic or physical. It may need cleaning, adjusting or a wire connection repaired. Also check the curly cord and its connections between the handpiece and telephone.
Nov 17, 2009 | Sakar Talking Caller-ID Speaker Phone
I cannot hear the person on the other end but they can hear me
you ear piece may need to be replaced you should take the phone to a repair shop and have them replaced the ear piece or look at the old one for you.
Mar 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
My phones rings I cannot hear the person calling
Its related to your phone volume..try to increase it using arrow keys upside...or it also be a connectivity issue from the operator.
Mar 21, 2009 | GE 25952EE1 Cordless Phone
Nokia 1208 - I can't hear what folk are saying
ur speaker phone is not working fine try to replace it or check it with your voice recording so it will confirm that u need to replace it or not
Mar 04, 2009 | Nokia 1208 Cellular Phone
Home phone rings,fax cuts in when talking to caller!
First try a reset on the unit: Try the steps mentioned bellow
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
All the setup seems to be right. Except it seems you need to check the rings to answer in your answering machine if it is set to lower than that of the Fax (it should be atleast 4 or 5 Rings)
And the rings to answer in the All-In-One is set to 6 Rings
And make sure you have the right distinctive ring pattern as triple (If possible confirm it with your telephone service provider) and set it appropriatly, to me it seems it sould be clarified first with the telephone service provider
Check the above and let me know if any problem
Good Luck
Oct 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
Lands Phones Logo
50 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
