Question about Datacard Group SP35 Card Printer
Is it possible to share Data card SP35 Plus Card Printer over the network and release printout from the remote computer.? When I release the printout it give error "the printer driver cannot access the required PC resources DR-00907" My operating System is windows XP.
3 Suggested Answers
SOURCE: want to solve my problem
Hi Supermarco:
You are experiencing a common problem whit card printers, usually it happens when the printer needs maintenance. Two things might be producing your problem:
It could be the rollers, may be they are dusty and the card slips, that produces the error message you are experiencing. To solve it I recommend you to clean the rollers using a lint free cloth moistened with isopropyl alcohol. You can press the cloth against roller and move it turning the blue knob located at printers left. I also recommend you to run a cleaning card to the printer as specified on users guide (every ribbon replacement), that will also help you.
Another possible cause of your problem is a blocked by dust sensor. Datacard printers sensors rarely broke, when they produce problems is always due to dust. You can buy a compressed air can and spay with air all the interior of printer, just don’t forget to remove the ribbon and cleaner roller first. In that way dust accumulated on sensors will be removed and your printer will work properly again. I recommend you to operate your printer in a dust free environment, this kind of printer is very sensible to dust and debris. If you still have problem don’t hesitate to ask.
Regards
Posted on Jan 11, 2009
  • 6 Answers
SOURCE: How to turn SP35 into a network printer?
There is not possible to run this printer on a network.
You have to upgrade to sp55 or sp75
Posted on Feb 03, 2009
I have install Driver of Data Card SP35 for windows XP, my software
Hello
The installation have not been suceeded. Just go to Add-Remove programmes, by cliking control panel, and remove the installed driver from there. restart the computer, and reinstall it. Make sure that the device is connected to the computer, and is powered ON. OK.
Jan 31, 2012 | Datacard SP35 Printer
The printer is not respondig.(DR-00901) in cp80-plus printer
If your looking for a new card printer...try www.getthatpart.com they have a few new in box Zebra HDP600 professional card printers if your interested.
Oct 25, 2010 | Datacard SP35 Printer
How do i upload firmware to an SP35 plus printer
This site has "utilities". They run under different levels of Windows, back to w2000. Grab the one that is right for your system and install it. It should guide you through the firmware (available from the same page) installation.
http://www.datacard.com/id-card-printer-support-and-drivers/sp35-plus-card-printer
Feb 01, 2010 | Datacard SP35 Printer
Want to clean using the cleaning card.how do i do it -data card sp 35plus
You can't - the Cleaning Card supplied with the replacement ribbons is for other models of the Datacard printer, not the SP35 Plus :(
Jan 22, 2010 | Datacard SP35 Plus Printer
When i try to print card it causes a paper jam all time. it used to print card but not now i feel this is a grat pity cause its a good printer. It doesnt matter which place i put card it just will not lift...
fter a clear card option has been installed in a Datacard card printer SP35 Plus or SP55 Plus, a card jam error my occur. The same error may occur when after replacing the main control board.
To clear this error the printer will need to determine the sensor type. For the printer to recycle through and make this determination, a power on test card is required using the appropriate clear or opaque card type to force the firmware to redetermine the sensor type. Each time the card is changed from clear or opaque to the other type, a power test card will be necessary to redetermine the sensor type.
For additional information about Datacard printers currently on the market, SP25 Plus, SP35 Plus, SP55 Plus and the SP75 Plus, contact our id card experts toll free at 888-485-4696.
Nov 19, 2009 | Epson AcuLaser C4100 Printer
Cards not feeding through on SP35
You will need to replace the Pick Roller (the first roller you see from the card hopper.
You most probably have a smooth roller and the new type are ribbed. The printer has to be dismantled to replace the roller. Suggest you contact your local reseller.
Jun 24, 2009 | Datacard SP35 Printer
Jan 21, 2009 | Datacard SP35 Printer
Just purchase a Datacard SP35 PLUS. My question is, how do I create a photo card? How do I save it. And DO I need to create a database to save photo's. What a template?
you just installed first the Quickworks which is the software of that printer then there you have to create a photo card and it has built in database.
Jan 13, 2009 | Datacard SP35 Printer
Data card sp35 plus ribbon break
There could be either of the following issues:
1. Check the print head temperature to make sure that it is hot enough to transfer the ribbon to the card.
2. The surface of the PVC card may not be image compatible. Try another brand of card or opt to 60/40 composite cards for testing.
For technical assistance by blog for id card printers, see our blog at www.safecardid.com/blog/
Jun 20, 2008 | Datacard SP35 Printer
Datacard Group SP35 Card Printer Logo
532 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
