Question about Sony PlayStation Portable (PSP) Console
How can downgrade my psp 6.31 to any other firmware because chickhen r2 does not work on a psp ofw 6.31........ please help
  • 4 Answers
You cant
Posted on Sep 19, 2010
I've upgrade my psp 5.03 chickhen r2 to 5.50 gen-d3. then i reboot my psp, and then my screen turn blank. i remove my mem card and batterry. and nothing happens.. plss help me.
upgrading/downgrading or installing CFW in PSP is a risky business. the rule of thumb is to know if you have hackable or unhackable motherboard. if you had 5.03 chickhen before, then most likely you have a PSP-3000 or PSP-2000 v3 which has unhackable motherboard. you should have just installed 5.03 Gen-C or CFW Enabler 3.70, or upgraded the OFW to 6.20 and installed 6.20 TN-E or 6.20 PRO-B. 5.50 Gen-D3 is for hackable motherboards like PSP-1000 or early versions of PSP-2000. you have bricked your PSP!!!
for more details, check out sites like pspslimhacks.com, pspcustomfirmware.com or qj.net.
Sep 01, 2011 | Computers & Internet
Tip
How to hack a psp without pandora ?
Since ChickHEN is out PSP-2000 owners with a TA88v2 or less or a TA90v1 motherboard now have the option to now install Custom Firmware without the need of a Pandora battery.We have put together a Easy installer that contains everything you’ll need. Hellcats Recovery flasher, ChickHEN, PSP firmware update 5.00.
Warning make sure you only try this on a PSP that will accept PSP Custom Firmware flashing (Custom IPL) otherwise you will brick your PSP!!! PSP-3000’s will not take CFW. Check your PSP will take CFWhere. Or run ChickHEN first, then when ChickHEN is loaded run PSPident from the Game XMB menu. (PSPIdent with install with this easy installer)
Steps to install CFW on a PSP Slim without a Pandora battery.
1. Check and triple check you have a hackable PSP that will accept
custom firmware flashing without resulting in a BRICKED PSP. Make sure you have a PSP with a TA88v2 or below only + or TAv90v1. If your PSP has a TA88v3 or above or is a PSP-3000 DO NOT proceed!!! You will brick your PSP.
Run the installer and point it to your Memory stick Pro Duo root.
2. If you don’t have don’t have PSP firmware 5.03. Get that here: PSP Firmware 5.03 Make a folder called UPDATE in your PSP/GAME folder and place the eboot in there on your memory stick pro duo.
3. Now lets run ChickHEN to have a homebrew enabled environment. In your PSP go to photo then click the ChickHEN photo and wait. If the PSP jams, please retry. If it flashes colours and reboots you have loaded ChicKHEN. Check your system info to be sure it say’s 5.03 ChickHEN R2. If you need help getting ChickHEN to run please visit this post.
4. Now with your PSP rebooted in ChickHEN go to your PSP XMB game menu and run Hellcats Recovery and install 5.00 M33!!! Your PSP will reboot, follow the instuctions to install PSP Custom Firmware 5.00 M33. After your done you can update to 5.00 M33-6
Easy ChickHEN CFW installer (Without Pandora) (27.9 MiB,)
visit www.newzgadgets.co.nr
on Mar 10, 2010 | Video Game Consoles & Games
How to chicken?
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Firstly make sure your PSP-3000 or TA88v3 PSP-2000 has PSP Firmware 5.03 installed. Check in your PSP XMB go to Settings/ System Settings / System infomation. If you don't have PSP 5.03 installed download it here. Create a folder called UPDATE in PSP/GAME on your memory stick and place the eboot from the archive into the folder. Run the 5.03 Firmware update from GAME / Memory stick and you will have 5.03. The firmware required to run ChickHEN.
Now download the ChickHEN R2 release from here. Open the CHickHEN R2 archive and place the folder inside Slim with gif images into your PSP memory stick location like so PSP/PHOTO (later it will be PSP/PHOTO/ChickHEN). Now place the h.bin into the root of your memory stick pro duo. Where the folders PSP, MUSIC etc are located.
Ok next step place the memory stick into the PSP. We have found this step helps ChickHEN boot with less attempts, go your PSP XMB, to settings and Restore Default Settings. Your PSP will reset, now go back into settings and turn off UMD Auto-Start and UMD Cache. We found ChickHEN loads in 2-3 goes after doing this.
Now go into Photo / Memory Stick and ChickHEN. And wait, you will see five egg giff images, these will start to load thumbnails. Your PSP may freeze and reset. Just keep retrying and ChickHEN R2 will load up....But if you see flashing colors, your PSP will reboot into ChickHEN your homebrew ready!
With ChickHEN R2 loaded now starts the fun part. (P.S You can put your PSP into standby now so you don't have to go through the whole process again)
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Sony PlayStation Portable (PSP) Console
How can i downgrade my psp 3004 wiyh a firmware of 6.20
You dont need to downgrade since you can use things like 6.20 TN-C/D or 6.35 PRO-B,but if you want to downgrade you must know if your PSP has a 03g or a 04g module.03g can downgrade to 5.00 then use ChickHEN R2 and then 5.03 GEN-C.04g modules cannot downgrade below 6.00 but there is no point in doing that since there is NOTHING avilable for 6.00/6.10.You can find out if you PSP is 03g or 04g with PSPIdent (you need HEN ofcourse).
!!REMEMBER!!
DOWNGRADING is AWLAYS risky especialy when you dont have a Pandora capble PSP.Downgrade at your own risk remember that there is no unbrick for 3000/GO/v3 motherboards.
Feb 27, 2011 | Sony PlayStation Portable (PSP) Slim...
How do i downgrade psp 3000 running ofw 6.31....help me please
Unfortunately there is nothing you can do at present to downgrade a PSP 3000 that has firmware above 5.03. Pandora battery does not work and neither does chickhen, until someone works out a way of enabling custom firmware on a PSP 3000 above 5.03 I am afraid you are stuck to official firmware.
Hope this helps and thank you for using FixYa
Sep 20, 2010 | Sony PlayStation Portable (PSP) Console
Psp1000
You can use ChickHen R2 to downgrade your PSP without a pandora battery. You need also to download the ofw ver. 5.03 and cfw 5.03 GEN-C to hack your PSP. You can find many ChickHEN R2, cfw 5.03 GEN-C and step by step instruction in the internet.
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
Please help me....
Use a pandora battery to flash anny firmware you like.
You have updated your custom firmware with the original firmware from Sony.
You'll have to downgrade your firmware to update to the newest custom firmware using the pandora battery or update using the pandora battery to update directly to the newest custom firmware build.
Succes.
Aug 31, 2009 | Sony PlayStation Portable (PSP) Console
Runescape on my psp
freewebs. com/ roshanb/ runescapeonpsp.htm helps(take out spaces)
Latest CFWEnabler : 05/07/2009
Download:
http://2f19b96d.seriousfiles.com
Changelog:
- Fixed a bug when playing within Infraestructure
- New system version
- Improved the Pops flashing system
- New update server.
Just copy the CFWEnabler folder into /PSP/GAME , then go to Games and run the installer
1)INSTALLING 5.03 OFFICIAL AND LOADING CHICKHEN R2
a)INSTALLING 5.03 OFFICIAL
Firstly, you CANNOT do this unless you hava a PSP with Version =<5.03 . To check your PSP FW go to Settings-> SystemSettings-> System Information . If the version is 5.03 , skip thispart and follow the guide below to install ChickHEN . If you have alower version follow this GUIDE in order to install OFW 5.03 .
-Download 5.03 OFW (http://135ff34d.seriousfiles.com)
-Connect your PSP to your PC via USB and create a folder in PSP/GAME named UPDATE.
-Copy the .EBOOT file in PSP/GAME/UPDATE.
-Run the update from your PSP .
Now you should have a 5.03 OFW PSP , just what you need in order to load the Tiff Exploit.
b)LOADING CHICKHEN R2
Some useful tips for those who can't get the ChickHEN to work :
-Restore Default Settings
-Set UMD Auto Start and Cache OFF.
-Make sure you're on 5.03 OFW
-Format Memory Stick. ( this will erase all the data from your MSso you'd better backup your files on your PC before doing it )
-Try another method as this video shows :
(http://ad452dd7.linkbucks.com)
-Don't give up , just try and be patient.
Note that the files needed for PSP 2000 and 3000 series are different than the ones needed for PSP 1000 so don't screw it up.
DOWNLOAD:
FOR PSP SLIM ( 2000 & 3000 ) :
-Download ChickHEN R2 Easy to Load
(http://0639570b.thesefiles.com)
FOR CLASSIC PSP ( 1000 ) :
-Download ChickHEN R2 Easy to load
(http://d249d993.thesefiles.com)
-Copy h.bin to the Memory Stick ROOT .
-Copy ChickHEN folder to PSP/PHOTO ( create one if needed )
-Navigate to your PHOTOS folder , and enter the ChickHEN folder.And wait, you will see some images, these will start to loadthumbnails.Go all the way down to the last image. Your PSP may freezeand reset. Just keep retrying and ChickHEN R2 will load up….But if yousee flashing colors, your PSP will reboot loading the ChickHEN.
For those who can't load the ChickHEN files check above for useful tips and remember to restore default settings.
Check your PSP's version to make sure. If the version is somethinglike 5.03 ChickHEN R2 you should be fine and ready to install CFW.
2)INSTALLING CUSTOM FIRMWARE
Do NOT try this on any PSP 3000 or PSP 2000 unhackable mobo's this is only for PSP Phat and 2000 hackable series.
This will permanently install CFW onto your PSP
ChickHEN must be enabled.
-Download Recovery Flasher 1.60
(http://926291d9.thesefiles.com)
-Download 5.0 OFW
(http://a3b04c08.thesefiles.com) -direct download
-Copy the Recovery folder to PSP/GAME .
-Also copy the 5.0 official update renamed as 500.pbp to PSP/GAME/RECOVERY folder .
-Go to GAME and run the program and install 5.0 M33-6 !
In the end , press SELECT while in XMB and change UMD Iso Mode to''M33 Driver'' or ''Sony NP9660''. I also recommend formatting memorystick. Place your CSO/ISO games to the ISO folder on your memory stickroot.
GUIDE created by : PSPgamen OF AFTERDAWN
Any questions ? probs ? post here !
Enjoy :)
Aug 26, 2009 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
109 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
