Question about Altec Lansing ADA 885 Computer Speakers
Hello, I have an Altec Lansing ADA 885 and wanted to connect it to a TV. I was just browing the net and found this post of yours http://www.fixya.com/support/t361655-compatability_tv . I was curious if it is possible to use my ADA 885 to get surround sound from the television. I am not too sound savy and not quite sure how it all works. Do I need a reciever to accomplish surround sound? My TV is a Sony Trinitron XBR. It has Audio out but I think only Left/right. What would it look like if it had more to accomplish surround sound?
Definately don't know what I am talking about but any suggestions/hints would be greatly appreciated. Thank you.
    Brigadier General:
  • 6,966 Answers
Thanks for posting direct. As you posted, the Sony XBR has only left & right (white/red) outputs whereas your Altec ADA has multiple INputs. This leaves us with no other option but to used just the green INput of the Altec as the black and the S/PDIF has nowhere to be connected to in the Sony.
You would need to use a phone stereo to RCA cable/connector as shown below. Additionally, you would have to set up your speakers as suggested here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 11, 2008
Dp/n 08506p drivers
I have ALTEC LANSING DP/N 08506P speakers om my Windows 7 PC. The left speaker works fine but no sound from the right speaker. I "think" this is a rather recent event. Can you help?
May 24, 2014 | Altec Lansing ADA 885 Computer Speakers
Cable setup for Altec Lansing ADA885 system needed
Try using the internet to get the information you need
Mar 01, 2013 | Altec Lansing ADA 885 Computer Speakers
How do you connect the altec lansing ada 890 speakers to a flat panel HD TV
You can use the audio output RCA outputs to connect to the speakers. You need to use a multi- connector to match the input of the Altec. You can get the mating connectors to the headphone to RCA which can be connected to the Audio outputs. Also you can use a network to match the input impedance, use a simple reisitive network.
Dec 09, 2011 | Altec Lansing ADA 890 Computer Speakers
Altec lansing ada885 took a dose of 240V, burned fuse in place, replaced fuse, worked for about 2 hours, now nothing
Well is the new fuse still good or out again. if its good, then you probably fried the main board on the amplifier. These computer speakers do not handel big power serge's.
Mar 12, 2011 | Altec Lansing ADA 885 Computer Speakers
Hello, I have an Altes lansing ad-885 system and I have lost the cable that connects it to the pc, Where can I purchase a replacement. Thanks,
Altec Lansing ADA 885 connects with an SPDIF cable. Something like this should do the trick for you:
http://www.amazon.com/Toslink-Digital-SPDIF-Optical-Performance/dp/B001ENJ3ZA
Dec 22, 2010 | Altec Lansing ADA 885 Computer Speakers
Broken pin on wire
I am not familiar with this model ... I must ask ... Are these standard electronic plugs? RCA, Mini or micro phone? Mon or Stereo?
Two souces that pop into mind are Altec Lansing or Radio Shack.
Thanks for your interest in FixYa.com
May 14, 2010 | Altec Lansing ADA 885 Computer Speakers
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Can I hook up my ada 885 to my dvd player& my flatscreen tv?
Yes. They are essentially Similar to any other 120 Watt Surround System for Home Entertainment. The Fact is, the only major difference is that the connections are different. On The PC it uses Stereo Standard Outputs. On Your DVD Player, It Will most Likely require an adapter to RCA (red/white -usually- Audio Cables). It just depends on your DVD Player. Have Fun!..... :)
Apr 20, 2009 | Altec Lansing ADA 885 Computer Speakers
How to hook my altec lansing speakers to my TV? and my laptop @ the same time
You can do this through a receiver (like a stereo receiver). Hook the tv up to line 1 and the computer up to line 2, then hook the stereo receiver output to the input of your subwoofer. Then shift the receiver from line 1 to line 2 (as easy as pressing a button on the front of the receiver) to hear either one through your speakers.
Nov 26, 2008 | Altec Lansing ADA 885 Computer Speakers
Compatability with TV
Yes but you will not enjoy all the features of the Altec ADA 885 speaker system and if the TV's features will allow you.
Most TV's do not have audio out and if ever they do, chances are that it will only be left/right. Your Altec ADA 885 speaker system is capable of getting multiple inputs other than just left & right; main, front, surround & S/PDIF.
Hardware wise, the standard audio connector to the audio outputs of your PC are baby phone plugs, while those in the TV are RCA. If ever you will push through, you would need to get hold of a stereo RCA to baby phone cable. Am not sure if the yellow dongle cable that came with your package is long enough.
Additionally, here is a link to the normal installation instructions for an Altec ADA 885 speaker system should you be interested.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Jan 20, 2008 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ADA 885 Computer Speakers Logo
772 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
