Question about Directed Viper Keyless Entry System (basic install included)
User Manuel or Directions For Sierra Tools Keyless Entry System
Disable keyless entry on 1999 ford expedition
I have never had to do this but I am told this is the correct proceedure.
Keyless entry key pad procedure
1. Turn the ignition to the 1 (OFF/LOCK) position.
2. Close all the doors.
3. Enter 5-digit entry code
4. Press and hold the 7 • 8. While holding the 7 • 8 press the 3 • 4.
5. Release the 3 • 4.
6. Release the 7 • 8.
The user should receive a horn chirp to indicate the system has been
disabled or a chirp followed by a honk to indicate the system has been
enabled.
Mar 05, 2011 | 1999 Ford Expedition
I have a Craftsman keyless gargage door opener model 031D0431. We just moved in and would like directions on how to recode the keyless entry. One more question...if I recode the keyless entry, do I have...
Coding the keypad will not affect the remotes if you follow these directions.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in a four digit code and press enter.
Oct 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
How can i tell if my 1990 gmc 1500 has keyless entry
All pre 1995 GMC vehicles had to have an alarm system to have keyless entry... So, lift the hood and look for a red LED near the right front of the vehicle. If none - you don't have keyless... if yes, the you do.... and an alarm system too.
Dec 31, 2009 | 1990 GMC Sierra
Keyless entry remote quit working. Just purchased new battery. Now Spare remote does not work either.
Transmitter Programming Notes Transmitter Programming
  1. Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
  2. Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds . The locks will again cycle once.
  3. Repeat step #2 for each additional keyless entry transmitter.
  4. Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete
Jun 17, 2009 | 2000 GMC Sierra
Keyless remote entry does not function, panic button does.
This link will take you to very good instructions try it worked for me www.wikihow/program-a-keyless-entry-for-a-chevy-silverado this works on GMC models also.
Mar 30, 2009 | 1999 GMC Sierra
2001 Mercury Sable Keyless Entry-Fuse
check this fuse first. I believe it's #30. Check with chart on fuse panel cover or in your owner manual.eb303fa.gif
Jan 10, 2009 | 2001 Mercury Sable
Keylees entry and remote controls do not work at the same time
There are two types of technology with this operator (rolling code and non-rolling code). This operator will except one or the other but not both. It is not uncommon for a rolling code (Security+) remote or keyless to lose the "rolling"part of its technology and become a non-rolling code device so it is not compatable with the rolling code technology. You will need to replace the one remote or keyless that is not like the others.
Nov 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
How to install a keyless entry system!
buy a system from a parts store and follow the directions
Oct 12, 2008 | 1997 Mazda Protege
I want to change the personnal code on the keyless entry on my garage door
Press the learn code button on the back (or side) of the operator. with in @ 40 secs. press in your 4 digit code on your keyless and press the enter button @ 2 secs.
Sep 28, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Directed Viper Keyless Entry System (basic install included) Logo
295 people viewed this question
Top Directed Home Security Experts
Are you a Directed Home Security Expert? Answer questions, earn points and help others
