Question about HP LaserJet P1505n Printer
One default vertical line is printing in the right side of the printable area on the printed paper
I have hp printer laser 1505, it can print out and i set the paper on portrait. but the output of printing out is the characters are on landscape style. So what should i do...plz help me if somebody can solve it
Posted on Jun 24, 2011
Why does Xerox 7335 truncates output from Oracle PDF?
It may not be the printer and I did some research on Oracle and this seems to be a common issue.
I pulled this information off an Oracle knowledgebase it may not resolve your issue and there is more info on the following site if you want to investigate further:
http://docs.oracle.com/cd/E23943_01/bi.1111/b32121/pbr_uxprt009.htm#RSPUB75727
NOTE:
If you're printing to the Xerox MFD with a PS (postscript printer driver) you could try installing and printing using the Xerox PCL driver for your computers operating system. If you printing reports from a mainframe this may be an issue at the mainframe level in which case I would engage your companies IT department for assistance.
Any one of a number of possible causes may account for the truncation of fields.
  • Check the field and determine if it is allowed to expand.
    1. In Oracle Reports Builder, double-click the field in the Paper Design or Paper Layout view to display the Property Inspector.
    2. Find the Horizontal Elasticity property.
    3. If it is set to Fixed, you should change it to Variable or Expand.
    4. Run the report to the printer.
    5. If it still truncates, it could be that the field requires multiple lines.
    6. Return to the Property Inspector for the field and check its Vertical Elasticity.
    7. If it is set to Fixed, you should change it to Variable or Expand.
    8. Run the report to the printer again.
  • If the right most fields on the page are always the ones truncating, it could be an issue with the printable area of the printer. If you are using a PCL printer, then you will have to estimate the size of the printable area and resize your margins accordingly:
    1. Open the report in Oracle Reports Builder.
    2. Go to the Paper Layout view.
    3. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins.
    4. Click and drag the black line to the left approximately 0.5 inches.
    5. Save and run the report to the printer again.
    6. If necessary, repeat steps 4 and 5 to determine approximately where the printable area boundary is located and then ensure that your report body fits within that area.
  • If you are using a PostScript printer, you can get the printable area boundary to appear in the Paper Layout view as follows:
    2. Choose File > Page Setup.
    3. Verify that the margins are small and that the orientation is correct.
    4. Click OK. The Paper Layout view should now be able to read the boundary.
    5. Go to the Paper Layout view.
    6. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins. A black hashed line also appears indicating the boundary of the printable area.
    7. Ensure that the thick black line is inside of the black hashed line. If it is not, click and drag the black line inside the printable area.
    8. Click the Margin tool to leave margin mode.
    9. If necessary, reposition your fields to fit within the new body boundaries.
    10. Save and run the report to the printer.
  • For PCL, if it is still truncating, try using a fixed space font instead of a proportional font. Sometimes PCL printers have problems interpreting proportional space fonts and it leads to truncation. You should try using a fixed space font, such as Courier, and possibly font aliasing.
    Note:
    Default layouts are built against a generic printer. Each printer has its own printable area. As a result, you may have to reset the report to fit the printer. Ideally, if you know the various printers you will be using, you can design the report from the start to fit the printer with the smallest printable area.
Mar 10, 2015 | Xerox Office Equipment & Supplies
Printing vertical green lines on photos
The troubleshooting section for banding below was taken from the user manual found at this web link:
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
White or Dark Lines in Printout
If you notice white or dark lines in your prints (also called banding), try these solutions before you reprint:
• Run a nozzle check to see if any of the print head nozzles are clogged. Then clean the print head, if necessary.
• Make sure the paper type setting matches the type of paper you loaded.
• Make sure you loaded the printable side of the paper correctly for your product.
• Turn off any high speed settings in your product software.
• Align the print head.
• You may need to replace the ink cartridges.
Hope this helps...
Dec 21, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
I have installed new cartridges but paper comes out blank
Hi Khalid,
Make sure your printer is set as the default printer on your PC.If you were printing many pages,try selecting the current or the page with the text only and try to print it.Check paper size settings,orientation,layout and printable area in your software and make sure they're in line with the paper you're using.If problem not solved,then you may need to clean the printhead to unclog the nozzles so that they enhance smooth flow of ink.
  • Connect the printer to the computer and turn it on.
  • On the taskbar of your PC,right click on the printers icon.[If there's no icon,go to your printer properties window and then click on the maintainace tab.Select on the head cleaning option].
  • Select 'start' on the headcleaning pop up window that will appear.
  • The printer will starting making noise and the green light will start to flash.
  • After the cleaning the green light will stop.Select 'print nozzle check pattern' and then click on print.[make sure there is a loaded paper in the tray].
  • Check the printouts.If gaps and lines appear on the paper,click 'clean' and if they're ok,click 'finish'.
Hope this helps.Thanks!
Please rate this answer.
Dec 01, 2011 | Epson Stylus C86 InkJet Printer
I have a canon mp 240 and it Prints fine if you only need half of the document. It cuts everything in half! Like it reads the header wrong or blows up the words or make extra spaces. How can I get it to...
I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I set my printer so my printout fits the paper size I am using?
Solution: Use the recommended Print Area MP240
Printing Area title-bar.gif To ensure the best print quality, the machine allows a margin along each edge of media. The actual printable area will be the area inside these margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. (o_darkblue13.jpg)
Printable area (light blue):
The area where it is possible to print. (o_lightblue14.jpg)
However, printing in this area can affect the print quality or the paper feed precision.
o_area15.jpg i_note.gif Note
Borderless Printing
By selecting the Borderless Printing option, you can make prints with no margins.
bullet_s.gif When performing Borderless Printing, slight cropping may occur at the edges since the printed image is enlarged to fill the whole page.
bullet_s.gif For Borderless Printing, use the following paper.
- Glossy Photo Paper "Everyday Use" GP-501
- Photo Paper Glossy GP-502
- Photo Paper Plus Semi-Gloss SG-201
- Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
-Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced quality. Use them only for test printing. You can perform Borderless Printing on plain paper only when printing from your computer.
bullet_s.gif Depending on the type of paper, Borderless Printing may reduce the print quality at the top and bottom edges of the paper or cause these parts to become smudged.
See A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See Letter, Legal.
See Envelopes.
sikaku.gif A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
3.73 x 6.80 inches / 94.8 x 172.6 mm
* This page size can be used only when printing from your computer.
o_ap_069.jpg o_darkblue6.jpgRecommended printing area
o_lightblue7.jpgPrintable area
sikaku.gif Letter, Legal
Size
Letter
8.00 x 10.69 inches / 203.2 x 271.4 mm
Legal*
8.00 x 13.69 inches / 203.2 x 347.6 mm
o_ap_074.jpg o_darkblue4.jpgRecommended printing area
o_lightblue5.jpgPrintable area
sikaku.gif Envelopes
Size
European DL*
4.06 x 7.12 inches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1 mm
* Envelopes can be used only when printing from your computer.
o_darkblue8.jpgRecommended printing area
Jun 30, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Http://img189.imageshack.us/i/93955650.jpg/ When you print a photo, color blue will be out on the first print. Why be like this?
You can find support for your print quality problems in your User Guide here:
http://support2.epson.net/manuals/english/ij/stylusphotor390/use_g/html/trble_3.htm#S-01200-00600-00200
I believe your problem is with vertical misalignment or banding.
Make sure the printable side of the paper is face up in the sheet feeder.
Run the Head Cleaning utility to clear any clogged ink nozzles.
Run the Print Head Alignment utility.
Clear the High Speed check box in your Advanced printer settings.
Make sure the paper type selected in the printer driver is appropriate for the type of paper loaded in the printer.
Links to help with the above solutions are available in the on-line Troubleshooting section under Print Quality Problems.
Feb 03, 2011 | Epson Stylus Photo R390 InkJet Printer
Paper won't feed through printer. (Lexmark X2690). Can't see anything stuck in printer. Paper won't go down past rollers, but I can't see down inside etc
Loading paper and original documents
1. Make sure:
• You use paper designed for inkjet printers.
• If you are using photo, glossy, or heavyweight matte paper, you load it with the glossy or printable side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
• The paper is not used or damaged.
• If you are using specialty paper, you follow the instructions that came with it.
• You do not force paper into the printer.
2. Before loading paper the first time, slide the paper guides out toward the edges of the paper support.
3. Load the paper vertically in the center of the paper support, and adjust the paper guides to rest against the edges of the paper.
Align the print cartridges
In Windows
  1. Load plain paper.
  2. Then do one of the following:
    - in Windows Vista, click pattlnk_852008_1527-vista-start-button.gif.
    - in Windows XP and earlier, click Start.
  3. Click All Programs or Programs, and then select the printer program folder from the list.
  4. From the printer folder, click Maintenance - Align Cartridges.
  5. Click Print.
  6. Follow the instructions on the computer screen to finish.
To clean the print cartridge nozzles:
In Windows
  2. Do one of the following:
    - in Windows Vista, click pattlnk_852008_1536-vista-start-button.gif.
    - un Windows XP and earlier, click Start.
  4. From the printer folder, click Maintenance - Clean Cartridges.
  5. Click Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
  6. Print the document again to verify that the print quality has improved.
Oct 28, 2010 | Lexmark Office Equipment & Supplies
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
Vertical line and five spots in every sheet of paper I print
Thats on the drum, time for a new cartridge.  The equial distance of the marks on the right side of the page point to the drum  which I presume is built into the toner cartidge.
May 30, 2009 | HP LaserJet 1012 Printer
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP LaserJet P1505n Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
