I wont to add more ram to my pc what memory module do i need. i have a hp pavilion xt963 Thank you.
  • 14 Answers
This machine uses PC133
There should be 2 slots and it will hold a maximum of 512MB
Some computer shops may not carry your type of ram any more; so I would call first.
Posted on May 11, 2008
I am looking to get a new hard drive for my pc.
Add more ram is it uses a lot of graphics it might be slow adding more Computer ram will make it faster.
HP Pavilion a6228x Computer Memory.
The HP Pavilion a6228x Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2 Memory Type, and comes installed with 2.0 GB (removable) of Memory.
You can upgrade your HP Pavilion a6228x Computer to up to a maximum memory capacity of 8.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB (removable) standard memory installed.
For best Pavilion a6228x Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use theCrucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible
Dec 26, 2013 | HP Pavilion a6228x PC Desktop
I have a HP Pavilion dv6700 special/limited edition. I start it up, and all lights turn on and i can hear the computer is on. But the screen is black. And then I hear a beeping sound three times. First one...
Sounds like you have a memory problem. Either a RAM module is defective & needs to be replaced, or the slot where the RAM module goes into is not making good contact between the motherboard & the memory module, & needs to be cleaned.
Try first cleaning the RAM module slot with a non-oily contact cleaner. Leave it to dry for few minutes then install the RAM module & test if the computer will turn on. If it does not, replace the RAM module with a working one & test again.
Sep 09, 2010 | HP Pavilion DV6700Z Notebook
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
When memory check starts, get a + then hangs
Computer unplugged from power, computer case open, observe Anti-Static precautions, then remove the ram memory module/s.
(Slang for ram memory module, is ram memory 'stick')
Use a pencil eraser, and clean the gold plated contact pins, on the bottom of the ram memory module.
Just rub the eraser on the contact pins.
(If the eraser on the end of the pencil is attached by a metal sleeve, refrain from letting the metal sleeve touch the contact pin/s)
When handling the ram memory module, refrain from touching the contact pins on the bottom.
You can handle the ram memory module anywhere else, as the body is coated with a see-through protective plastic.
Lay the module on a wood table, or other non-Static surface when cleaning.
Example of a DDR Sdram ram memory module as used in a Pavilion 523n,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
Use air to remove the eraser dust.
(You can use a can of compressed air for computers, or air pressure from your mouth is sufficient)
Reinsert the ram memory module/s. Close the computer case, plug back into power. Wait 1 minute, turn the computer on.
[Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
Working on a table, computer unplugged from power, computer case open, TOUCH the metal frame of the computer case (Unpainted surface) to relieve your body of Static.
Should you get up, and walk away in the middle of working on your computer, upon your return Touch the metal frame again ]
Opening your computer case.
Looking at the Back of the computer, there are two screws on the far right edge.
One above, one below.
Remove the two screws, slide the side panel back about 1 inch, tilt the side cover top to the outside, remove the side cover. (If memory serves)
Should you need guidance in removing, and reinstalling a ram memory module, hit me up in a Comment.
(Believe upper right of your page. Fixya is constantly under going change to improve the website)
HP Support > Pavilion 523n > Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07767&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=90387
HP Support > Pavilion 523n > Motherboard Specifications (Scroll down to see an illustration of the motherboard, and photo below it)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07899&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=90387
Jun 15, 2010 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
I have 4 banks of ram slots. Can I keep the Bank1 256k Bank2 256k. Can I put 1G into bank3.
It is strongly recommended that you install RAM in matched pairs. So if you add a 1GB module in bank 3 then you should add 1GB in bank 4
But you can add just the one module and it should work, but not at optimal speed.
http://www.crucial.com/store/listparts.aspx?model=Pavilion%20a1410n
Jan 12, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
Want to add RAM to my Pavillion DV 1000 and I know
Refer to the manual that comes with your Notebook when you purchase it.
Here is the manual link for Hardware & Software guide
http://h10032.www1.hp.com/ctg/Manual/c00569409.pdf
Download the manual if in case you don't have it. and open it with adobe reader.
Dec 28, 2009 | HP Pavilion dv1000 Notebook
Can I use one 1G ram module to upgrage memory or do I need 2 512 modules for my HP Pavilion 533w
yes, you can providing it is the same family, ie ddr2888 or 553 ect but might slow machine down, It is always better to do an exact match,
Oct 03, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I have hp dv-1000 laptop with 256 ram, which i wud like to upgrade to maximum.so how many GB ram i can go for and what wud be the price.?Can i go for 4GB ram?
You can upgrade to 2Gb ram. I dont think your notebook will support 4Gb ram. A 2Gb Transcend ram will cost you around 1500 bucks INR
Sep 01, 2009 | HP Pavilion dv1000 Notebook
Memory upgrade
Add 1GB ram modules in slots 3 and 4 for a total of 2.5 GB RAM. $98.00 plus tax not bad.
http://www.crucial.com/store/listparts.aspx?model=Pavilion%20a1230n%20Series
May 14, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
