Question about Canon PIXMA MP780 All-In-One InkJet Printer
Just switched on my printer after 2 months and have the "wrong cartridge" message flashing.
    President:
  • Canon Master
  • 2,017 Answers
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Sep 03, 2010
The screen gives a message that says wrong T/C type. Is this the toner cartridge? As it has been running for weeks with the toner cartridge that was replaced last month
one way to fix this would be to turn the machine power switch while holding down the no key and panel reset key and change the t/c
Jan 26, 2011 | Konica Minolta Di1610 Copier
WRONG CARTRIDGE
Press the reset button if they can correct that problem. Maybe you can used the not genuine cartridge on your printer or it could be not properly inserted your cartridge. Try to power off the printer and check your cartridge then power on it again.
May 29, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Printer keeps flashing wrong cartridge with correct cartridges
make sure all in correct. Clean sensors and cartridges then delete and reload driver. if this does not correct issue, then you have a faulty cartridge
Oct 10, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
My printer is not printing..page comes out blank. inside, all the lights are flashing on the ink cartridges...any ideas what's wrong? thanks
this message means that the cartdriges are empty...
if you have bought new cardridges and lights still flash then the printer just dont recognize them right.
possible cause 1:
dirty cartdrige (or printhead) chip contacts > clean them with alcohol and cotton (switch printer off first).
see the chips in this photo:
https://secure.datatekusa.com/images/canon%20PGI5.CLI8%20refillable%20cartridge.jpg
possible cause 2:
bad printer controller: the chip in the printer that communicates with the cartdriges is gone mad... take the printer to service...
all the above are valid assuming you bought original cartdriges if not then do so...
Sep 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
MP730 Canon printer the LCD display flashes wrong cartridge
What's the message?? If it says wrong cartridge then you need a new printhead.
QY6-0064-000 around $40.00
Jul 03, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
HP Laserjet 1300 printer Yellow light flashing
dear friend,
when the printer give you a yellow flash that should be means a fault happen so you have to do the following:
1- check if any messages appears on your computer when you trying to print something that should be help you. if not go to step 2
2- black paper may be come from the (P.C.R.) that is the charger of the drum, so if you can open your cartridge and check the charger at the op of the drum that will be good and if not you may change the cartridge and check again.
3- Also, you can release the cartridge and look inside the printer may be you can find something wrong or something need to fix
4- Other wise go to hp help center
Jan 28, 2009 | HP LaserJet 1300 Printer
Canon Pixma MP750 Printer
try to reinstall the printer cartridge
Jan 15, 2009 | Canon PIXMA MP750 All-In-One InkJet...
HP PSC 750 - Gives message - check cartridge or wrong cartridge..
You could try to clean with alcohol the metalic looking part of the cartridge. If this doen't work, you should replace it and try a new one. I would suspect the the ink has dried on the cartridge and is clogging the jets. .
Nov 27, 2008 | HP PSC 750 All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
35 people viewed this question
old marine
old marine
