Im having trouble with the settings on my fisher and paykel intutivie washing machine.It will wash but not rinse or spin. What can I do?
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Now, does the machine drain the water?Does the machine stop and beep and show an ERROR CODE?Does the machine fill for the rinse part of the cycle?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Posted on Sep 03, 2010
My Fisher Paykel washing machine won't spin it's goes to rinse then stops. The wash light and the last rinse light comes on also spin light comes on and it's beeping
Fisher & Paykel technician in your area
Contact
Http://www.fisherpaykel.com/au/support/service-appliances#
request-a-service
Customer Care - Online Locator
Feb 18, 2016 | Fisher Washing Machines
Ian,
Which wash light? There are a total of 8 lights in the sequence on the panel. From left to right, can you give me the numbers of the lights that are on. I have a Fisher Paykel fault code manual, so I can look it up if you give me the lights that are lit and also give me the model of your machine, some of the codes are different for different models.
Aug 13, 2015 | Fisher Washing Machines
Fisher & Paykel WL80T65CW1 - Washing machine keeps saying unbalanced.
Yes the shop you bought it from. At only 12 months old the warranty should still apply.
Nov 03, 2017 | Fisher and Paykel Aquasmart wl80t65c
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
Paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
Feb 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
