Question about Refrigerators
Door will not shut tight
I cannot get a tight seal on the door
  • 3 more comments
  • beegfoot Jun 26, 2008
    Talk about timing. I learned of this site in a Wall Street Journal article this morning an hour or so AFTER I had called an appliance repair company to make a visit. Our fridge is about 5 years old, model # ARB 8057C. It's a 'freezer drawer' model vs. a 'freezer door' type. The unit pictured seems to be similar but our fridge is one of the narrower depth models (about 4-5") that fits with the profile of the surrounding cabinets. This problem has been slowly developing for some time but gotten rapidly worse in the past few days. Clearly, the gasket at the bottom of the sliding door is more compressed than the upper, which is where I suspect the air is infiltrating. Massive frost in unit this morning. Why that is, I am not sure but the chief suspects are in order: (a) early failure of gasket due to inherent design problem, (b) misaligned hinge (as suggested here) but I have checked for this problem before, (c) unit not properly leveled (good suggestion, will check). The key to correcting this problem going forward is to figure out why the sliding door is angled away from the mating surface of the unit. My guess is this a typical issue with these units
    -Rich
  • Snuggers1 Dec 01, 2008
    refrig door will not shut completely. It appears the door is too low and the plastic shelving is scrapping against the lower right corner interior plastic.
  • Lil Pip Dec 10, 2008
    The bottom freezer of my refrigerator will not close tightly. The top of the door tilts out and the bottom is pushing in. How do I adjust the door?
  • Anonymous Feb 12, 2009
    I have A gap in the top left of my seal on my freezer door, I just replaced my seal because I thought that was my problem but it wasn't
  • trophychick Mar 06, 2009
    Refrigerator door (top) has sagged, and there is no adjustment in the hinges. Had it repaired under warranty, but a year later, it's sagging again. Have to really push, and lift, to get the door to seal.
Could be the following
Fridge not level to floor - adjust or chock untill level
Seal old or deteriated - replace with new seal
Door out of alignment with frame - adjust hinge assembly if possible
Damaged door - Replace
Obstruction from inside fridge- Check and clear if possible
Posted on May 11, 2008
buddymcl777
  • 67 Answers
SOURCE: freezer door not sealing
replace the seals and / or have the hinge adjusted
Posted on May 01, 2009
  • 363 Answers
SOURCE: Side by Side Fridge door doesn't seal completely
i would clean all of the door seals with a damp rag, and all of the contact points, also you can adjust the level of the unit a little in the front
Posted on Jul 30, 2009
txinspector
  • 379 Answers
SOURCE: intergrated fridge door no longer shtting tightly
some refrierators have magnets at the bottom of the door. some times the magnets get moved out of place and the door no longer makes contact with them. try looking for the magnets with a steel screwdriver and inspect to see if they are in the correct place.
Posted on Aug 01, 2009
Number5Gayle
  • 98 Answers
SOURCE: refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Posted on Aug 09, 2009
  • 57 Answers
SOURCE: seal around door is not
Is this unit new? Is it new to you? Has this problem just developed? I need the history to help you. If it is new, you have a year warranty. All units built today are as air tight as possible. When one door is opened and closed. The other door can pop open. To alleviate this issue the unit's front levelers must be adjusted to tilt the unit back slightly. The door or doors might still pop open but will close by themselves. If I can help you futher, let me know.
Posted on Mar 30, 2011
LG dryer doesn't dry clothes on one cycle. Lint collects around bottom of door rubber seal. Have noticed, the door is not closed tight. How to get door to stay closed tightly?
It sounds like you have a plugged up vent causing air to try to blow out around door instead of out vent. Also check door latch to see if anything is broken.
Mar 28, 2016 | LG Dryers
My bottom drawer freezer (kitchenaid) is accumulating alot of frost and the door seal seems like its not sealing
You need to clean the bottom of the door seal and then kinda fluf the seal a little bit by pulling on it and allclean out all the frost and make sure nothing is in the way of the door shutting tight.
Jul 07, 2011 | Refrigerators
The refridgerator door is not sealing properly and the magnetic seal between the refrig door and the freexer door is hot.
Heat the seals with a hair dryer and then pull it tight - strap it tightly shut - you can also use some super glue to keep it in place while it dries.
Gary @ Fix Ya
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Oven door will not shut tight at top
The door is not tight per say. The seal is hat determines if it is properly closed. Check to see if the seal is tight all the way around(use a strip of paper to check consistency). If it is not sealing the hinges are tweeked and need replacing.
Eric
Feb 22, 2010 | Kitchen Ranges
Refrigerator side not sealing tightly when shut.
Good Luck
Aug 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Jul 25, 2009 | Refrigerators
Freezer door not sealing
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Profile Door Seal
There is a cam at the top of both doors the grab on to the fridge to hold the door s shut. There has been a problem with them breaking and not holding tight. Check the door and make sure the cam is gripping the cabinet correctly.
Oct 31, 2008 | GE Profile PFS22 33" Artica French Door...
Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Jan 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag dishwasher mdb5000awa leaking
Well did you check to see if the door seal is ripped or not on tight??? The door seal is the rubber strip that is used to seal the door shut tight, if this is wrecked in any way that might the the answer to your solution?
Dec 20, 2007 | Dishwashers
Refrigerators Logo
1,341 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
