Question about Cameras
Does a canon pc1108 camera need a seperate batt charger or can you plug it directly into camera, if so where?
2 Suggested Answers
  • 11967 Answers
SOURCE: My Samsung L73 digital camera will not charge.
Have you recharged the battery many times since you owned it? Did you leave it alone for an extended time and it completely discharged and died? Rechargeable batteries sometimes only last 3 years.
Posted on Jun 14, 2010
I dont know what is going on with my camera, but i i charged the battery and now it wont turn on. i dont think i over charged the batt. because it wasnt on for that long. PLEASE RESPOND SOON i have a...
Rechargeable batteries can and do just die without warning.Sometimes the charger does so as well. The charger automatically prevents overcharging though.
Realistically, all you can do at short notice is to try another freshly charged NB-6L battery. if a camera shop has a display model they might allow you to try their battery in your camera, or more likely, your freshly charged battery in their camera.
Jul 22, 2011 | Canon PowerShot SD1300 IS IXUS 105...
How can i check if which need replacement my batt or my charger coz when i charge my batt the led lights on then after a while it turn of the led light then ill unplug it and plug it then still the same...
Power Source Li-ion Rechargeable Battery (LI-42B) Are you using the above battery?
Check the voltage to make sure it has enough as printed on the charger or the battery.
Alkaline rechargeables, or NiMH rechargeables, or other types of batteries don't have enough voltage or amperage as compared to Li-ion.
Jul 03, 2010 | Olympus FE-280 Digital Camera
My Samsung L73 digital camera will not charge. Batt is dead. When I plug the charger in, the camera led turns green, then orange, then off. No matter how long I leave the charger plugged in, it will not...
Jun 14, 2010 | Samsung L73 Digital Camera
I plugged in the charger and after an hour the blinking power button stopped blinking and the camera now does not turn on? M1093 IS camera
If the cam. was plugged into the cam and on. Then it doesn't charge it only transferres pics.
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 12, 2009 | Kodak EasyShare M1093 IS Digital Camera
Lens popped out and won't charge
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth and reinsert
Pls test with an alt. batt./ charger
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or new charger.
Contact KODAK:
Oct 27, 2009 | Kodak EasyShare V1003 Digital Camera
Hi, we just bought a new power cord for our camera and when we plug it in it blinks green once and red three times and then it doesn't charge. is there anything we can do to solve this problem? it is a...
Remove the memory card and the battery
Use the camera w/o the memory card
Contact KODAK:
Oct 08, 2009 | Kodak EASYSHARE M1063 Digital Camera
My canon fs 100 doesn't turn on
I took the camera to the representative and we started various tests such as:
Tried My battery in OTHER camera .... not working
Tried OTHER battery in MY camera .... works
Tried charging MY battery in OTHER Camera .... works
Tried MY battery in MY camera and charged .... worked
Bottom end is that my charger is not working although it heats when "charging".
Now i will look at the pins in the charger to see if they are working or not.
Whatever the case .... getting a new charger.
May 29, 2009 | Canon FS100 Flash Media Camcorder
No power, all buttons flash when connected to ac charger
if charger voltage is ok then it could be phones charging controler is not working. if phonebook is only thing you need could recharge battery directly from your charger and then save your phone book. cut off charging plug-connector from your charger make two bare wires and then apply red wire to battery "+" and blck to "-". 5min of charging will be enough to copy your data
Jul 21, 2008 | Samsung SGH-c225
No power coming through charger to camera.
there are four little fuses on the mainboard but you wouldnt be able to repair them they would need to be fixed but there also could be a problem with the lens sometimes on that model that could cause the problem you have described sometimes when i repair a power cam problem it will act up again and the mainboard needs to be replaced its a good camera but a problem like that you should send it in if you still have a warranty or upgrade to a zr 830 or 850
Nov 10, 2007 | Canon ZR600 Mini DV Digital Camcorder
Cameras Logo
243 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
