Question about Samsung Televison & Video
My remote controller is not working it just adjust volume.
  • 901 Answers
Try opening the remote control! Give a try with a small screw driver, by inserting the screw driver in the locking grooves.
Removing the snap-on, bottom and top covers. Remove the graphite rubber mat, pcb.
Wash the mat with distilled water or clean drinking water. Use little washing soap mildly. Wash it two to three times dry the mat using a hair dryer.
Same way clean the PCB and dry with Hot air. Re assemble & the remote should work now!
You can also use Isoprophyl alcohol or after shave lotion for the above cleaning the PCB.
Posted on Sep 03, 2010
Bought a genuine remote off eBay for a Harman Kardon HK 3250. Drives everything fine except the volume control. Would it be faulty or doesn't it work due to a wind volume control?
Turning, or winding, volume controls can still be adjusted with the original remote control. You should check to see if it is the exact remote that originally came with your model. Different model remotes might control some functions, but not others. The remote is most likely not broken, just the wrong one.
Apr 28, 2017 | The Audio Players & Recorders
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
Can not adjust volume
dere may bea problem wid d battery ,try replacing the battery ...if the laptop is in warranty den get d remote repaired ... although u can repair it urself by opening d remote and rubbing d contacts wid some metal
Feb 09, 2010 | HP Mobile Remote Control For Pavilion...
What is the 5 digit code for sylvania 26'' lcd tv
Go to comcast.com they have a remote link for codes
Dec 22, 2008 | Televison & Video
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
Volume control
I know this isn't the best solution, but my Logitech Harmony 720 remote controls my hts3450 just fine (volume included).
Nov 12, 2008 | Philips HTS3450 System
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Open Questions:
Televison & Video Logo
569 people viewed this question
Jerry Greenberg
Jerry Greenberg
