Question about Kirby Ultimate G Bagged Upright Vacuum
Hi....Need Help please....
The belt on my Ultimate G Kirby Vacuum fell off. I'm trying to figure out how i put it back on. I've taken the roller brush out but don't know how it hooks onto the hook in the back. Thanks in Advance!
  • 1,673 Answers
Put the belt on the brush roll, place it in the nozzle, make sure the belt is in the center, turn the big knob on the front until it locks, then install the nozzle on the vac., turn the knob in the other direction, and it will be put on the pulley.
Posted on May 13, 2008
My Kirby Ultimate G does not have enough suction to pick up pet hair. Is there anyway this can be corrected? I felt under the vacuum when it was running, the roller is running, but I felt very little...
An Ultimate G has lots of suction. If you turn on your vacuum and the bag immediately inflates - that is how you can tell if your Kirby is moving air (suction). There is a more modern brush that came out with the Ultimate G Diamond and the Sentria that has stiffer bristles that dig up pet hair better.
Another way to test the suction is to spread some baking soda onto a hard floor and vacuum it up - you can see how much suction your Ultimate G has, or take off the vacuum head and put on a hose and test the suction at the end of the tube.
Ways to increase your Ultimate G cleaning efficiency. Take off the vacuum head and remove the brush roller. Attach your hose attachment and **** vacuum out the head. Put on a new belt, and remove any hair and or string or threads that may be wrapped around the brush roller. Put the roller back on and on the ends of your roller you will see that the ends spin and have numbers on them. If your vacuum brushroll is original - you could have your bristles rather worn and so you can align the #3 on BOTH sides of the brushroller. This would be a good time to consider upgrading to the Sentria Brush.
Remove the bag, and replace with the CLOTH Kirby bag. It has the best filtration and it has the best airflow (which increases what you are referring to as suction). If you want to go the cheap route - at least get the paper Micron Magic with HEPA filtration (but it has slightly less air flow)
Remove the side mini emptor from the vacuum and check to see if there is anything clogged up on either the vacuum or the mini-emptor.
If your engine is running and inflating the bag and you replace the belt, the brush roller and to the cloth dust bag - your vacuum should pretty much run like a brand new Sentria Vacuum. Your vacuum system is outstanding, but may benefit from a little TLC if you have been neglecting it.
Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
My belt broke on my kirby G-5. I havent put a belt on it in 10 years. I having problems getting it on.Can u tell me the right way? Thank you.
I recorded a video repair of replacing the belt for the Kirby generation vacuum cleaner. The following video will walk you through step by step on how to replace your Kirby belt, as well as doing some basic maintenance to the roller brush to prolong the life of your belt as long as possible.
How to Replace the belt on a Kirby Ultimate G Vacuum Cleaner;
I hope that this video was helpful to you in repairing your Kirby. If you found the video to be helpful, please kindly rate the video helpful by clicking on the Thumbs Up Icon below.
Thanks for watching!
Chris J.
Nov 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have problem with the belt and roller how to put
I read the fixit website about getting the roller off on maybe a newer version of Kirby vacuum cleaner is there a solution for the same problem with the Utimate G?
Aug 17, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Chris J.
Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
I have no idea how to put the belt back on
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Replacing brush roller on my KIrby g6 limited edition
You need a new belt. When the green light goes out, that means your brushroll has stopped spinning. Here's how to change it....
Even if you just replaced the belt, this guide will help you make sure that you got the brushroll back in the right way.
Hope it helps....
Dec 08, 2007 | Kirby G6 Bagged Upright Vacuum
Roller Brush
Try a new belt. The ends of the brushroller are different sizes, so you can't put it in backwards. There are numbers and notches on the ends of the brushroll. These notches/numbers need to match on both sides when installing it. (probably need both ONES face up). Make sure that the beltlifter arrows are green on green before you install the brushroller. Once you get the brush in and the baseplate back on, turn arrows to red on red to lift the belt up before reattaching the nozzle to the Kirby. I have included a link to help with other potential problems. If you want a manual, or need any more help, contact me through the links on my guide page.
Oct 19, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 vacuum
Here is a link to the help you need,,,
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Sep 17, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuum brush roller with belt attached is off
It is meant to come apart for cleaning it up afterwards. Slip the belt over the roller. One triangular end of the roller is bigger than the other, so keep this in mind when sliding it into the cleaning head. Turn the knob to pick up the belt, just like on the vacuum's regular nozzle. Mount the cleaning head, then turn the knob to set the belt onto the motor spindle.
Apr 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
73 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
