Sylvania LC320SS8 32 in. LCD Television I was watching tv and it went black. Can't get the tv to come back on. I have checked outlet and the surge protector. Any suggestions what could be wrong with this? Thank you
No, the tv will not come back on at all.
Posted on May 11, 2008
  • 34 Answers
Hello
can you hear sound or green light on front is coming on, please let me know.
Thankyou
Sylvania tv not recognizing DVD player
Do one thing press the SCREEN MODE button on the remote repeatedly and check is there is any difference in the screen. If there is no difference then yu tv Have problem wit the T Con board, T con board is on which drives pixels the lcd screen. You can find the T con board of your tv in the following link.
Normally you can find the T con board inside the tv at the bottom center covered by metal cover or aluminum foil. Replacing this board will solve the problem.
http://www.ebay.com/itm/BUF320G04012-T-CON-SYLVANIA-LC320SS8-/140556173476
If you need any more assistance feel free to contact me through fixya
Ajin
Nov 23, 2011 | Sylvania LC320SS8 32 in. LCD Television
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
I have a Sony Bravia XBR 46". It is 18 months old. The left 20% of the picture is fine, but the right 80% flickers in horizontal bands. Pushing back lightly on the upper right corner of the bezel and...
Please make sure that the connections are secure.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please try connecting the TV to a different wall outlet and check if that helps.
Jun 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sylvania 32" LCD HD TV LC320SS8 went off and will not come back on. tested the outlet it is fine
Sounds like a bad power supply or a bad power control board/circuit board. This seems to be a bit common with these lcd's.
May 14, 2009 | Sylvania LC320SS8 32 in. LCD Television
Random turning off/on while watching tv
sounds like it could be a power issue. is the powercord on the back of the tv detachable? make sure its plugged in tightly. also if using a surge protector reset surge protector. if not using a surge protector try a different outlet. also if gfci outlet (has reset button on outlet itself) try resetting the outlet by pushing the reset button
Apr 04, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Flat panel tv blows fuses
next to the fuse that blows is 4 large black diodes2.gif.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
Nov 10, 2008 | Sylvania 6626LCT 26 in. LCD Television
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
No picture and no power LED
Hello. I have the exact same tv. and the same thing happened to me! What i did was buy a expensive Surge Protector and now it works! I hope this info is useful!
Apr 20, 2008 | Sceptre Naga III X30XSV 30 in. LCD...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
