Question about RCA Televison & Video
I`m an electronics tech that having a problem with a rca model#L32WD22 with no video through the tuner or video inputs.all the tv do is come on and the "no signal" go across the screen.the tv go through all the tv functions,but will not lock -on any tv stations when auto programing. the tuner signal video p.c.b.#CBPF6Z1KA8 is no longer available.can you please help me with this problem
  • 1 more comment
  • www_doctroni Sep 03, 2010
    the rca tv#L32WD22 do have on-screen video ,but no composite video cooming through the tuner nor video inputs using dvd`s players as video signals coming in all the external video input jacks.
  • www_doctroni Sep 27, 2010
    Sorry for getting back so late ,but been so very busy. If you said this other p.c.board will work, i'm going with that. getting back to your other qeustion, all inputs sources doesn't work (show video) when using outside sources. Cold solder joints good appoach that i have to check very good. can you e-mail me back to make sure the other p.c board you suggested will work and part store it available at if possible.Thank you kindly to your respond. Please e-mail back.
  • RCA Master
  • 5,807 Answers
CBPF6Z1KA8 may no longer available but:
CBPF7Z1KZA2
Main Unit | Main Board | Audio/Video Board | Tuner Board | VGA Input | Head
is still available:
you might also consider having a separate tuner or
a set- top box
But have a check on the VIF sections, it could just
be a cold solder joint or a possible setting on the
Circuits.
Posted on Sep 03, 2010
  • Rommel Cana
    Rommel Cana Sep 03, 2010
    can you try using other source ?
    like a Video Camera, a VCD player an IPod
HOW TO GET AN USER MANAUL FOR A RCA MODEL L32WD22 TV
I suggest you try the support section of the manufacturer's website where user manuals are often available for free download.
Feb 11, 2015 | RCA Televison & Video
How do you hook up a DVD player to a RCA LCD TV?
If they both have HDMI inputs and outputs use those. If not use the RCA audio and video jacks. Make sure you change the settings on the TV so it knows where to look for the input signals.
Aug 13, 2014 | RCA L32WD22 32 in. LCD HDTV
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button.
I hope this helps.
Apr 16, 2013 | RCA L32WD22 32 in. LCD HDTV
How do you replace a coax antenna port that was pulled out from the back of the tv
On most sets the tuner has to be removed for this to be done-a new fitting or a new tuner can be installed.
If the set has the standard RCA audio and video jacks for input you can hook a cable box or even an old VCR to those and BYPASS the coax fitting--hook up to those inputs--select them on the set and leave set on that input and change channels with the box or VCR.
Much cheaper than replacing the fitting and gives a better picture.
Apr 11, 2012 | RCA Televison & Video
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
I have a RCA 52"
This happens all the time. It just might be fixable. This connector is known as the "f" connector or female coaxal connector. Most average electronics technician can fix them. This connector is attached to a component called the tuner. The tuner is what takes the signal and selects the channel the tv recieves. To replace the connector it means removeing the cuircit board that the tuner is on and then removeing the tunner, disasembling the tuner. Now until you find a good tech, there is another option... take an vcr and use the rca inputs on set. essitally tunning the set through the vcr. Now you will have to change channels through the vcr. but it will work. also there is a chance that the tuner might be damaged. just depends on the damage that occured when the connector was broke off..,let me know if you need any more help
Jun 03, 2011 | RCA HD52W56 52" Rear Projection HDTV
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
I want to hook laptop up to tv
after you hook the cable up to the tv, go into the tv's menu to make sure the input mode is set to s-video. then go into the control panel on your laptop and find the settings for your video card and set the output to "TV" or "Clone"
Let me know :)
Dec 24, 2008 | Toshiba Satellite A35-S159 Notebook
Cable connector repair
use RCA cables instead of ch 3
Oct 24, 2007 | RCA D52W15 TV
I can't select TV/Video input on the menu
If you have the original remote (RCA Universal with red and blue buttons), you can switch from the TV tuner to the audio/video input with the INPUT button. It is to the left of zero on the numeric keypad, above the red CLEAR button. Press it again to get back to the TV tuner.
Sep 10, 2007 | RCA F27636BC 27" TV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
