Question about Samsung Washing Machines
I have a WT 7100 Samsun Washing Machine. When I switched on yesterday, I found that there emanates smoke from the machine. I wanted to get it repaired as soon as possible. Can you please suggest a nearest authorised service centre at Chennai ?
  • 262 Answers
SOURCE: smoke from washing machine
CHANCES ARE ITS THE MOTOR START MACHINE RUN IT IF POSSIBLE FOR A FEW MINUTES TILT MACHINE BACK AND FEEL THE MOTOR IF IT IS HOT YOU NEED TO REPLACE IT (THE MOTOR)
Posted on Dec 11, 2007
IB4G2008
  • 3587 Answers
SOURCE: Bosch Washing machine WFB 4001
well, seems to me that you are using too much juice for the circuit, which implies a SERIOUS issue with the machine. perhaps the motor is locked, or something in control panel is shorted out?
Posted on Feb 27, 2008
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
localwonder
  • 6784 Answers
SOURCE: lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
Posted on May 22, 2009
SOURCE: Maytag Ensignia Smoking
I had the same exact problem, called a repairman to take a look..he informed me the motor has burnt out! His first thought was the transmission, and said having the motor burnt out is better since it is less expensive.
Posted on Jun 03, 2009
SGW-7100 s
No question there !!
Aug 11, 2014 | Washing Machines
Filling with Water and then stops
replace the tub motor drive belt
Dec 03, 2013 | Whirlpool Washing Machines
Manual for lg washing machine wtr854
LG has the manual for the WT-R854 on their site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-R854.jsp . Click on the Support tab and then look on the right side of the page.
I hope this helps.
Jan 12, 2012 | Washing Machines
Hi i have a samsun top loder washing machine wen i prest sart it wont start keeps beeping and i just displays DE how can i fix this
Hello
This code means door error.There is a problem with your door magnet or switch not making contact or closing the loop to allow washer to start.
Try cleaning off the magnet if there is one,or checking that the switch itself is not loose or broken.
Please unplug machine before doing any of the above.
Apr 01, 2011 | Washing Machines
Merry Christmas! Our washing machine whirlpool
Hello there and merry christmas to you too
ok please read this solution fully this will be posted in 2 posts so i can get it all for you ok
There are a couple of different reasons that this problem happnes on these machines i have this listed below please feel free to leave me a comment on any of these if you need help trying to figure out how to inspect them or test them ok but you will need a multimeter to do most of the testing.
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) i will continue in the next post
Dec 26, 2010 | Whirlpool Washing Machines
Trouble with washing machine
This could be a broken belt. It sounds like something jammed the machine and the belt kept turning until it burned and broke.
Sep 25, 2007 | Washing Machines
Washing Machines Logo
91 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
