Question about Trilogy T3-17B1 Monitor
I have a t3-17b1 touch monitor,but I found touch cable is interrupt,that cable is connected with screen, so I cannot touch screen, I need to buy it .can you help me?
Pavilion 23tm. the touch screen doesn't work.
Touch screens need drivers just like your mouse does. HP will have it. Whether it works with your computer is another question.
Mar 28, 2014 | HP Pavilion 23tm 23-inch Diagonal Touch...
Asus laptop power light on but monitor have no signal
1. check if the RAM memory is well placed. Try to clean the connecting pins and re-insert (do not touch the circuitry area of the memory, hold at the edges) or replace the ram memory.
2. make sure the screen cable inside is well fixed of not interrupted.. to make sure of this, connect to an external monitor, then switch on the computer.
good luck
Sep 07, 2013 | ASUS Eee PC 1000H Laptop
Touch screen pos
You'll need a VGA Port on the computer to connect another monitor. Check the cable that comes out of the monitor and see if there is a spot on the computer that it will connect to.
May 24, 2012 | Touch Dynamic Stinger (TD121) PC Desktop
I purchased a 3M 15"
This display uses a capacitive touchscreen. It relies on the conductivity of your finder work. It may be that it has lost sensitivity and only works when there is a path to ground through your body. If this is the case then the touchscreen will need replacing.
Feb 18, 2011 | 3M 11-4922-129-00 (Black) 15 in. Flat...
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
HP rp5700 appears dark and its not the touch
Disconnect the monitor cable from the computer tower, turn on the monitor, if no display available, the monitor gone bad, else if getting message " Check video cable", either the data cable for connecting the monitor to the tower needs to be changed or the motherboard needs to be tested thoroughly.
Jun 29, 2010 | HP rp5700 POS Terminal PC Desktop
Install software for touch screen elo
try this link : http://www.elotouch.com/Support/Downloads/dnld.asp
Jun 09, 2008 | Elo 15" Touch Monitor
Nintendo ds damaged ribbon cable
You can't buy a ribbon for the bottom screen. (You can buy the ribbon that connects the motherboard to the daughter board which connects the top screen.). A new screen is the answer but be very careful when taking off the touch screen. Gently pry the two screens apart or else you will need a new touch screen. Also make a note of how the touch screen is attached to the LCD screen, as the touch screen is not the same size as the LCD screen. How have you damaged the ribbon? Could it be that it may not be pushed tight and straight into the connector? BTW the top and bottom LCD screens are the same. Some unscrupulous dealers have been charging differing amounts for 'Top' or 'Bottom' screens!
Oct 27, 2007 | Nintendo DS Console
Trilogy T3-17B1 Monitor Logo
66 people viewed this question
Top Trilogy Computers & Internet Experts
David Payne
David Payne
Are you a Trilogy Computer and Internet Expert? Answer questions, earn points and help others
