My children have found a couple of Digitech DC1005 walkie talkies. They are working as we;ve installed new batteries but have no idea how to get them started. Do you have a manual available?
  • munch642 Sep 03, 2010
    Thanks for the info. I think santa might have to bring some new ones.
  • 11,800 Answers
The button on the left, front case, starts it. The 2 buttons on the right, front case, selects the channel. The other 2 buttons selects the mode - make sure that both are on the same channel and same mode. To speak just press the big button on the side.
If the unit doesn't starts then it's defective - the reason it was thrown away.
Posted on Sep 03, 2010
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
I need a manual for a Digitech dc-1005 walkie talkie
Hi Mitchell,
I own a Digitech DC1065 80 Ch CB HH, and no problems, so far.
Have you tried the Digitech website?
If so with no luck, may I suggest you join yahoo group specific to your radio Make/Model, there are experts with great info, plus you can download manuals, diagrams and software, etc.,,
I hope this is of help to you. (Ibought my DC1065 on ebay, no manual, but found the unit easy to work out, but I've got a bit of knowledge with radio equipment).
Cheers,
Peter
Jan 20, 2013 | Radio Communications
Motorola walkie talkie randomly cuts off
buy professional radios and you get better battery contacts
dont go to work with child's toy
Mar 22, 2012 | Motorola Walkie Talkie 2-Way Radio
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
Walkie talkies were working yesterday (gift from Christmas) and today the red power light is on indicating both working, but we can only get sound out of one of them.....any suggestions? brand new...
These walkie talkies are pretty simple to use. Turn on and turn the volume up and talk. So if you turn it on it is possible for there to be enough juice in the batteries to make the LED function but not enough to modulate (or talk) to the other walkie talkie. Have you tried to replacing the batteries with new ones yet? Sometimes recharge ables go bad and they are no good when you install them into your item. So make sure the batteries you installed are "new." And replace in both units. Should this not work, given the nature of the item and the age of those who will more than likely be using them, they break and soldier joints come loose. The back has a screw that is a specialty tool to remove. Outside of removing that and taking a look there is not much that can be done. Make sure to put at least 5 feet between the two radios to allow for good reception.
Regards, Tony
Apr 17, 2011 | Digital Blue LEGO Walkie Talkies
How do I change the channel on the Digitech DC-1005 walkie talkie? THanks
Looking everywhere online for an instruction manual for my little green and yellow walkie talkies ( Digitech dc-1003) without luck, so I had to work it out for myself.
The first button with the circle with line though it is the on/off button but it is also the channel select button. Hold it down for 2 secs to turn it on or off, OR press it once to be able to choose channels (the flashing number can be changed using the triangle up and triangle down buttons). Once you've chosen your channel, press the on/off button to select Hi or Lo frequency then press on/off button a third time to save. If you don't want the annoying static that sometimes comes, press the on/off button a fourth time for the squelch function (saves batteries and eliminates annoying hiss).
The next button is "S" which is the scan button. Hold it down to start scanning through all channels to try to pick up a transmission (we found a conversation between two fishermen today). When it finds a transmission, it will pause to let you see the channel number then continue. Hold down "S" button again to go back to original channel.
Next button "C" is the Call button. Pressing this button transmits a beeping alert to people on the same frequency/channel to let them know you are about to transmit a message.
The trangle up and triangle down buttons control the volume or select channels (as mentioned above).
Hope this helps. :)
Dec 27, 2010 | Audio Players & Recorders
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
561 people viewed this question
 Grubhead
Grubhead
