Question about Sony KV-27S15 27" TV
Sony tv only loses color on digital cable premium channels
My sony tv is 13 years old, and I have never had a problem with it. I have had Comcast digital cable with all the premium move channels in the past and also never had a problem.
Recently, after moving to a new house, I added the HBOs and STARZs to a digital lineup that I had for a while which already included the Encores. Now when watching some of any of those movie channels, the tv will go B&W for about 30 sec, and then go back to color, then BW, then color, and so on.
I do not have any issues with an of the channels that are not premium channels and did not used to have any issue with the Encores. THe problem is most persistent with the primary channel - HBO-East, Starz-East, and Encore-East, but it does happen to some, but not all, of the others in those families.
I thought the issue was the cable signal as the problem seemed to to happen more frequently when I was using the Comcast VOIP phone. Today, the tech checked my signal, we did some rewiring in case there was interference. We also switched the box again as he said this is usually a box problem. None of this has helped. I had already tried all of the cable box outputs, which didn't make a difference.
Tonight I hooked up the box to a portable color tv along with the sony tv and noticed that when the sony went BW, the other tv did not. So now I am thinking that it may be the tv.
But, how can a TV not be able to process only certain channels while it has no trouble with any other channels or other inputs, like DVDs or DVRs?
Another little note - I also noticed that the picture is crooked since moving the TV. The letterbox and channel guides sag a bit to the right.
Any thoughts are most appreciated.
  • sbwinter2 May 11, 2008
    More depth please -
    So how does a bad tuner not function correctly for only a few premium
    cable channels? How can a tuner tell the difference, especially when I
    have multiple tuners on that tv and they all have the same symptom? And
    really, I am not tuning in the channels, I am passing thru the cable
    tuner to the tv as a monitor.
    Scholar:
  • 131 Answers
Yes it is your tv since the tech ruled out the cable box.
1.possiable bad tv tuner cost of repair is 120.00
2, picture tube causes this sometimes but rear to be tube.
3.I would call a local tv shop and have them come out to look at find out how much they charge for road calls .
4.I like sony tvs i would keep your price around 225.00 for complete fix max
Thanks doctor video
Posted on May 11, 2008
I hooked up my proscan to comcast cable, i can just get first 13 channels.i tried going into settings and doing channel search, it will only clickon analog, not digital channels what can i do to get the...
Cocast may have only transmitting NTSC Ch 2~13 only for your area, to get more channel you may have to use Comcast cable box, I am in bay area, I can get 2~35 for basic plus service, I can get 2~13 for the most simple service for less money. What is your serivce level you are paying for?
Your TV also anly has NTSC tuner, there is no QAM or ATSC turner.
TV SPEC; http://reviews.cnet.com/flat-panel-tvs/proscan-26lb30qd/4507-6482_7-33403393.html
You may have to call Comcast.
Mar 09, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
TV Cable card slot loses signal immediately after channel find
may be tv main board problem ..if you can switch  cable HD  box you can  save money
Jan 08, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
How do you hook up to the comcast digital unit to
tune your tv to channel 3 if you're coax cable, if you're using rca or component cable then tune your tv to the proper input on your tv.
Jun 26, 2009 | Apex Digital AD-1500 DVD Player
Suddenly SNOW on all channels
your tuner has failed;
time for another set the cost to repair is too high
May 29, 2009 | Televison & Video
No cable channels at all on old Sony Triniton
make it sure that the coaxial cable has its own signal! if your tv has a raster (sometimes blue) and it says that the tv is good, but if there's no channel at all then the problem is in digital converter or the connection of the coaxial cable comes from..you can also try auto programing but if the problem still occured then contak your cable subscription channel
Apr 03, 2009 | Sony KV-13M10 13" TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Is Audiovox VE1020 HDTV compliant?
Audiovox VE1020 is not a digital set. To see digital broadcast you will need another digital reciever or a long lead to connect to your existing one.
This set does not have very good reviews either.
Hope that helps!
Jun 06, 2008 | Audiovox VE1020 10.2 in. TV/DVD Combo
Can't View Cable RCA f32444
You will have to go in the menu and switch it to cable mode, then do an autoprogram and you will have all the channels.
Sep 04, 2007 | RCA F32444 32" TV
Colors Off with High Def Comcast Cable
check your cable connections between tv and box, especially the red connector, try unplugging and plugging back in the cables.
Jul 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
270 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
