Question about Dishwashers
Wiring diagrame for westinghouse virtuoso dishwasher
  • elizajean Sep 03, 2010
    Westinghouse SB921SH is the Model No of my dishwasher
  • elizajean Sep 05, 2010
    I need to access the service programme on the dishwasher to finish installing new circuit board
  • 19,396 Answers
Posted on Sep 03, 2010
  • Dishwashers Master
  • 3,247 Answers
It might be easier to locate the wiring diagram if you can provide a model no. for your virtuoso dishwasher, eg. SB925 etc.
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Is it easy to get to the circuit board and how on the Westinghouse Virtuoso dishwashers?
Please mention the nature of the fault seen on the machine. It is possible that a failure of the main circuit board means that in most case the board had to be replaced as there is very little that be done for component replacement except if the damage is clearly visible.
Jan 02, 2013 | Dishwashers
Dishwasher Westinghouse SB915 fills with water for wash cycle but does not wash.
Contact Westinghouse directly to request the wiring diagram.
May 30, 2017 | Dishwashers
My westinghouse virtuoso sensor wash dishwasher isnt cleaning things as good as it should. I dont have a manual as I have just brought this house with dishwasher. Please help?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things...
Bought new spray arms online and installed them in minutes...now the thing works like new...
However I have also found that if the heating element goes bad then that also can mess things up bad...
So I would buy new spray arms, and also check out the heating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Sep 24, 2010 | Dishwashers
Hi My westinghouse virtuoso does not heat the water any more and i wan to know were is the heating element located please
if you want to see all the parts you can go to searsdirectparts.com and put in your model # and you can view every part and location of your machine.let me know if this helps.
Mar 06, 2010 | Dishwashers
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
Westinghouse dishwasher virtuoso SB 925 not heating the water and not drying the dishes , still workig thou. Would it be expensive to repair?
I also had this problem of the water not heating up but the washer still did its thing. what i found was the problem, is the soldered joints on the circut board were cracked (dry joints) around the relay area, i just resoldered them and hay presto its all good
Aug 20, 2008 | Dishwashers
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Circuit diagram for WEstinghouse Virtuoso Side by Side Fridge
It helps us to help you if we have a model number to work with. I have a site called www.mymarcone.com that if I have a model number, I can look up virtually ANY appliance diagram. Please post on this again with a model number and I will do my best to help you.
Dishwashers Logo
349 people viewed this question
Top Dishwashers Experts
