Question about Asko W6021 Front Load Washer
On a short cycle (6) it takes 2 hrs to complete and the washing isnt warm on completion (temp 60 degrees I have had a man in to fix it and he changed the element. This has not fixed the problem. Asko W6011
  • 1,998 Answers
Did he check the water valve first to assure that hot water is going into the machine through the water valve you can check this buying using a multimeter and checking the voltage going to the vavle and disconnecting the hose on the inside of the machine to assure that hot water is coming in through the vavle please write me back with your finds thanks again
rickead1
Posted on Sep 03, 2010
  • 3 more comments
  • Dawn Burns Feb 24, 2012
    I have the same problem with my Asko w6011 washing machine, it take 2 hours on the short cycle. is this problem expensive to fix or would it be better to replace it my machine is approx 10 years old.
  • Rick Ead
    Rick Ead Feb 25, 2012
    Also check the pump for any clogs in the line before and after the pump if the water is not able to leave the tub then this could also cause the problem due to the clothing being to wet when the load is finished? I await your reply thanks
    Rick
  • Dawn Burns Mar 11, 2012
    I have checked the pump and there are no clogs in the line is there anything else I can check.
    Thanks
    Dawn
  • Rick Ead
    Rick Ead Mar 12, 2012
    By checking the pump did you also check the flow of water coming out of the drain line as well if the flow is restricted then water is not leaving the machine how it should also your drain outlet should always be 6 inches above the top of the machine as well to maximize the pumps ability of pushing the water outward as well. How much water is left inside the tub during this two hour run time? Is the unit going into the spin function as well? have you assured that the impellar on the pump is spining? I await your reply
    Thank you
    Rick
  • Rick Ead
    also you can perform a continuity test or ohms test on the element as well as the thermostat as well to assure the water is getting to tempreture if either are not functioning then the water would not be heating.
    I await your reply
    Rick
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
I hear water running in my freezer and can see it dripping inside the freezer through the grate in the back panel. As this is happening the freezer will warm up to almost 32 degrees. I have to press the...
they are no longer 6 or 8 hour timers they are adaptive defrost and the more you open and close the door and the moreyouchange the settings the more often it will go into defrost. There is no set time on these models for the defrost cycle.
Jun 06, 2011 | KitchenAid (KSRD22FKST) Side by Side...
I need to get it inspected and everytime i go they say the computer isnt reset from where the engine light was on and i unhookeed the battery. also when i push the gas petal to accelerate from a stop. it...
A vacuum leak will do all that for you, aamco trans will check that light on code in the computer for free.You would be smart to find someone to check your computer for all codes because it will tell you without wasting money on bad advise.
Sep 29, 2010 | 2001 Dodge Caravan
665.15824000 dishwasher
What is your water temp. This model has 4 automatic water heat cycles built in to it and it heats the water to 145 degrees and won't let advance till that temp. If the water coming in is lower than 120 degrees it will add about 2 hours to your normal wash cycle.
Feb 12, 2010 | Dishwashers
Dishwasher takes hours to run through wash and dry cycle. what should normal cycle time be?
2 to 6 hours is possible. The newer machines have a water heat cycle that will raise the water temperature. lets say your incoming water is 90 degrees. The machine want to see 140 -165 depending on the cycle so that cycle will take 75 minutes to reach 165 (1 min per degree temp rise). multiply that by the number of wash and rinse cycles and it can run a very long time. Water should enter the washer at 120 degrees minimum. let it fill and measure the temp you will be surprised. Eric
Sep 13, 2009 | Kenmore Dishwashers
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Runs forever! even on Normal wash...help !!
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Fisher pakel washer taking too long to wash clothes
How long does it take to fill the tub? if the water, on warm stteting, isn't blasting out fast or if, when set to cold, it's trickling out, your cold water valve is shot. I can help with this problem 'cause I had the same experiences you listed.
Oct 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Asko W6021 Front Load Washer Logo
69 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
