Question about HP LASERJET P1006 Printer
HP Laserjet P106 - "door open" - will not print
2 Suggested Answers
  • 138 Answers
SOURCE: Hp laserjet 3030 problem
Remove and replace the side covers again. One of them (I think right) has a tab that pushes an interconnect lever that if not reinstalled correctly or carefully will cause this error.
Here's the HP Service manual to walk you through it again.
http://www.feedroller.com/Store/Service%20Manual/LaserJet%203015%203020%203030%20all%20in%201%20sm%20MFP.pdf
Hope this helps you.
Posted on Aug 05, 2008
How to solve hp laserjet 4350dtn fuzzy print?
usely it's the fuser sleeve the problem. replace the fuser but before be shure the cartridge is ok. print something and open the cartridge door when printing to see under the cartridge the print quality if ok replace the fuser unit
Nov 30, 2016 | HP LaserJet 4350dtn Printer
How do i install a new cartridge
Welcome to FixYa!
Toner cartridge replacement for HP LaserJet 3055.
Press the cartridge-door release to open the print-cartridge door.
Remove the print cartridge from its packaging, and then rock the cartridge gently five or six times.
Bend the plastic tab at the end of the cartridge.
Pull the tab until all of the sealing tape is removed from the cartridge.
Hold the print cartridge by the handle and insert it into the all-in-one and then close the print cartridge door.
I hope this helps.
Thank you for using FixYa!
Jas247
Apr 02, 2011 | HP LaserJet 3055 Printer
Describe your HP LaserJet 1012 Printer Problem light flashing
If your HP Laserjet 1012's attention light is flashing,
Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Mar 12, 2011 | HP LaserJet 1012 Printer
HP LaserJet 1020 won't print. Error: HP LaserJet 1020 has the front cover door open or the toner cartridge is missing. The door is closed and the toner crtridge is installed properly. I tried to upgrade...
Did this just suddenly happen or was it after you replaced the toner cartridge or opened the door?
I have found that if the toner cartridge is not completly positioned into the printer, it can give this error.
Feb 23, 2011 | HP LaserJet 1020 Printer
What does ! in a circle mean on an HP 2035n printer
The printer cartridge door is open. Attention
The print-cartridge door is open. Close the print-cartridge door Attention
Jan 28, 2011 | HP P2035N LaserJet Monochrome Printer
Triagle light blinks on HP Laserjet 1022
If only the triangle light blinks then is because one of the following reasons:
1.The print cartridge door is open.
2.The printer is out of paper.
3.The print cartridge is installed incorrectly. Try opening the door, removing the cartridge and installing it again. It should snap into place.
4.There is a paper jam. Remove the cartridge and check if there is a paper jam.
Feb 06, 2010 | HP LaserJet 1022 Printer
Paper jam HP Laserjet 3050z
Open tray 1 and pull any visible jammed media out of the all-in-one.
If no media is visible, open the print-cartridge door, remove the print cartridge, and rotate the
upper media guide. Carefully pull the media up and out of the all-in-one.
Close tray 1.
Aug 26, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 1000 series problem
First close the front door then try printing.
if problem persists contact to fixya again
Aug 19, 2008 | HP LaserJet 1000 Printer
How to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
2 Use the brush located next to the sensor to remove all toner
particles from the sensor.
Jun 06, 2008 | HP Color LaserJet 8550dn Printer
Back Door Printing
be sure that all bathe sensors work smoothly
Apr 30, 2008 | HP LaserJet 4250n Printer
HP LASERJET P1006 Printer Logo
825 people viewed this question
Seeker5211
Seeker5211
