Question about RTO Iroda Solderpro 70 Butane Gas Soldering Iron Kit
No gas coming out of the tip even the gas tank is full .......how to clean the tip ?
Why fuel gauge not working gas guage on 2009 santa fe stays on empty even with a full tank of gas. Guage fluctuates from empty to 3/4 full to empty to 1/3 full at any given time.
It could be the sending unit in the tank or the gauge on the dash. A mechanic would test the signal coming from the sending unit to verify.
Jan 19, 2014 | 2009 Hyundai Santa Fe
Full tank, igniter clicks, i hear the flam come on but it wont light. What to do?
I am not sure which flame you hear light. The pilot light flame or the burner flame? In any event, the burner and the pilot assembly need to be cleaned. Insects love to build nest in these types of heaters, when they're not in use. When that happens, the pilot and/or the burner get's clogged.
A shop vac with a hose and brush attachment work well in cleaning the heater parts. Canned compressed air with a straw nozzle (like you clean your computer with) does well in blowing out the pilot tip and around the entire pilot assembly.
Be sure to turn the gas tank valve OFF and disconnect the hose and remove the tank, before attempting to clean the unit. When you replace the tank and reconnect the hose, be sure to open the gas tank valve VERY, VERY SLOWLY (Slow motion slow).
Hope this helps you solve the problem. Thanks for choosing FixYa.
Sep 21, 2011 | Endless Summer 200209 Open Flame Patio...
Why a have push the gas pedal to start if I don't
YOU NEED A TUNE UP.REPLACE SPARK PLUGS AND WIRES, REPLACE AIR FILTER AND FUEL FILTER,CLEAN FUEL INJECTORS USE CAN OF SEAFOAM POUR IN FUEL TANK.FUEL TANK CAN HAVE 3/4 TO FULL TANK OF GAS.SEAFOAM WILL FLUSH OUT CARBON ON TIPS OF FUEL INJECTORS SO THEY CAN SPRAY WIDE NORMAL SPRAY.
Aug 21, 2011 | 1999 Oldsmobile Alero
It cuts out when the engine tips forward. When the float bowl is removed, the gas runs out onto the ground, but when tipped forward it stops, even on a full tank of gas.
When you say when tipped forward do you mean with the float and bowl on or with them off? I will suggest a few things to you without knowing the answer to my question and just hope it helps you even a little.
When bowl removed fuel runs out, (is that with the float still on?) this tells me there is no blocking of fuel in the line. The height of the float has to be set to manufacturer specs. The float itself should not be leaking. Remove float and shake it and try to feel if gas is in the float. It is difficult because float is so light and even a small amount of fuel will change the fuel level in the bowl and should be replaced. Also try to see if the float or inlet needle might be sticking or binding somehow and will not allow its full travel. Another thing might be the fuel filter and fuel line in the gas tank stuck in one position and when the tiller is tipped forward it is not picking up fuel or the filter might have come off. I hope this helps you out even a little. I will gladly answer any questions. A little more info might help also. Best regards and good luck.
Dec 20, 2010 | Honda Clutch Cable F200 F210 F260 Tiller
Grill will not ignite even with manually trying
Can you hear or small gas? It's possible to may have turned the propane tank valve on too fast. Close the tank valve, disconnect it, then reconnect it. Slowly turn the tank valve back on and try lighting it again. Hopefully this is your solution, but let us know if you need more assistance. Or check out my Tips & Tricks for gas grill lighting problems, just click on my user name and scroll down to my Tips & Tricks and see if any of those solutions help.
Douglas
Jun 04, 2010 | Weber Summit Platinum C4 (LP) Grill
Gas had moving from full to empty after i fill up
sending unit in tank may be shorting out or the wire to tank is shorting try removing plug connection and applying some electrical cleaner and plug in and remove 4 or 5 times to clean plug contacts they may be dirty worst case replace sending unit in tank.
Jul 01, 2009 | 1998 Pontiac Grand Prix
Fuel tank shuts off long before tank is full
the vent tube that runs beside the filler hose is crimped shut or clogged
Jun 29, 2009 | 1999 Chevrolet Silverado 1500
Even with a full tank my 2005 Envoy XUV fuel light stays on and fuel gauge marks empty
u need to change this gauge or try to dissasseble and clean it very well then try to install it back again
Jun 06, 2009 | 2005 GMC Envoy Xl
Removing gas tank on 1991 geo storm to replace fuel pump
I would suggest you get a Haynes repair manual for your Geo. They are GREAT manuals and cover just about everything from small repairs to even doing a full engine rebuild. I use them all the time .. full detailed explanations and pictures/diagrams. The whole process from beginning to end to remove your fuel tank is even in the manual.
Here is the link to the manual
Mar 24, 2009 | 1991 Geo Storm
When i try to pump gas in the tank even though it is not full gas will come back out as if it is to full
Spyder web in vent (that lets air out while u fill)
Try cleaning the lines going to the fill check valve or cleaning the lines going to it. It might be on or near the charcoal canistor or behing or on top the tank.
Or replace valve and lines
Sep 06, 2008 | Chevrolet Malibu Cars & Trucks
RTO Iroda Solderpro 70 Butane Gas Soldering Iron Kit Logo
81 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
