Question about E-Machines eMachines Desktop PC
My emachines e725 laptop turns on and shuts back off. When it is turned on the hard drive and fan come on and the light also comes on but then in about 2 secs it turns off. How do I fix it?
4 Suggested Answers
kamal1984
  • 1383 Answers
SOURCE: Emachine T6520 Wont Start Up
Check your num lock key status press it on and off if hum lock led is on and off when u pressing then your cpu working fine. so check connectiopn of vga cable cpu to monitor.
Also some times display screeen resolution issue so when u power up press F8 key then enter in enable vga mode then you can chang escreen resolution to 1024*768.
but if num lock key is not on and offf then open the cabinet of cpu then find cmos cell on mother bord and pull it for 14 minutes then check .
Posted on Jul 04, 2009
SOURCE: emachine laptop e725 ethernet driver
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17526
Posted on Aug 20, 2009
SOURCE: i shutdown my emachine E725 through windows it doesnot shutdown automatically and hands and ive to shut it down manually through power button
I had the same problem on E725 model, I fixed it by installing XP SP3.
Posted on Sep 12, 2009
Changed hard drive on emachine e725 now says no bootable device insert boot disk. dont have boot disk
You will need to install the operating system on the new hard drive for it to boot.Also you need to set you're boot order in the bios to CD then the HARD DRIVE.Get the operating system set the bios boot order then install it.
Mar 28, 2013 | eMachines eM250-1915 Netbook
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
My screen won't come on when i turn on the computer, it's an acer emachine E725 2520
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 27, 2012 | Computers & Internet
Hi, I have an Acer Emachines E725 laptop whose fan is not working making my laptop hot. Could you please suggest me some solution to it. Appreciate your response at your earliest. Thanks.
If your E725 is still under warranty I would let eMachines fix it for you. If not, try:
Clearing out the fan housing by using a can of compressed air and blowing through the vents.
Power off the laptop and on the bottom you will find the HD compartment, RAM compartment ect; Remove the covers and clear out as much dust and dirt as you can. Replace covers and test.
While the laptop is running attempt to kick start the fan's motor by using compressed air, a screwdriver, or a LIGHT tap to get the fan spinning.
Apr 13, 2011 | Computers & Internet
I turn it on and the fan begins to spin up, blue power light comes on and then after about 30 seconds it shuts down
hi, probabily the procesor fan does not works , other options is your opering sistem is bad, format and reinstall windows , other option is your hard drive is bad , try with another hard drive
Aug 12, 2010 | eMachines T5224 PC Desktop
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
May 02, 2010 | Acer Aspire 3000 Notebook
Emachine E725 touchpad does not work
It's that simple. I hope this helps.
Apr 14, 2010 | Acer Aspire 3000 Notebook
E-Machines eMachines Desktop PC Logo
350 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
