Question about Intel D845GVSR Motherboard
Hi i have the following issues with my pc which has intel d845gvsr mobo n intel pentium 4 processor: 1. when i power on the pc cpu fan starts running with cpu power automatically comes on 2. keyboard light flashes for a second and so cant enter setup utility 3. desktop light keeps on flashing and only the blank scree 4. no drive activity i tried with another pc and only the desktop works with it. can u pl tell me if its problem with bios chip and if so how to resolve it. ranga
    President:
  • 2,022 Answers
Yes it is problem with this type of intel original motherboard i advise you to go for new motherboard because this board is outdated and specially this problem occurs in this type of motherboard i face personally this problem .which is hard to repair. It is better if u think of updating the system then go for it. don’t waste money to buy new motherboard.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Sep 03, 2010
Hai, my pc mother boaed cd had lost, i want mother board cd to downloadf or System Model: D845GVSR,and Processor: Intel(R) Pentium(R) 4 CPU 2.40GHz, how can i solve this proplem
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+845+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D845GVSR
Sep 03, 2011 | Computers & Internet
Yesterday when i switched on my PC...some spark comes near cpu fan...then my ups is working properly and other accessories are working properly, but cpu alone not starting....there is no sound in...
Take a look closely at ur mobo, tell us where the spark came from? look also at the underside that may have touch the casing, check also the power connection from the PSU(Power Supply Unit) to the board connector!
Nov 11, 2010 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
FAN OK BUT NO DISPLAY
I like that. Kinda' rhymes. "Fan OK but no Display"
Problem is your Processor isn't turned on.
You have a bad Power Supply.
> Weak voltage power rail.
You probably have a 200 to 300 Watt power supply. (SMPS)
1) ALL of the LED lights together use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 watts. Depends on what Processor it is.
The Intel D845GVSR motherboard uses a Socket 478 processor socket.
Supports Intel Celeron, Intel Pentium 4, and Intel Celeron D, that utilize a Socket 478 processor socket, and have a maximum FSB of 533MHz.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Utilizes the Intel 845GV motherboard chipset.
[ Intel 82845GV Northbridge chip, and Intel ICH4 Southbridge chip ]
89 Watts is the maximum wattage, that can be used by a Processor for the Intel D845GVSR motherboard.
Power Supply has enough power to light LED lights, and spins fans, but not enough to turn the Processor on.
No Processor operating, No computer.
No computer, No video signal to the monitor.
(No Signal)
Do you have access to a KNOWN to be good, compatible Power Supply, for a test unit?
Motherboard Manual in PDF file form:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845gvsr
Under the heading > Documents and Guides, left-click on > Product Guides for D845GVSR.
Then left-click on the first file listed.
Product Guide - PDF File Name: D845GVSR_ProductGuide_English.pdf
Nov 03, 2010 | Intel D845GVSR Motherboard
Emachine 4250 wont boot gives 3 beeps
beeps indicate a hardware fault, go to the manufactures sight to determine the nature of the fault
Jan 25, 2010 | Computers & Internet
Cpu wont start
you should first check your motherboards condition and then look for an other cpu. Normally the mobo brake down more often.
Oct 23, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Mobo giving startup problem!
you have to narrow down the issue.. is it with the pc? or monitor? if you think the cpu... is the power supply fan working? is the cpu overheating? if you think its the monitor...be sure the card is seated properly and check all cables
May 30, 2009 | Intel D845GVSR Motherboard
My computer won't start but power supply and Motherboard is okay
if i understand correctly you swapped the cpu to another computer and it did not work... you need to purchase or find another cpu that is compatable with your motherboard.
Robert
Aug 25, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
My 4-pin cpu fan is not running
check the power connection for your mother board and fan
Mar 09, 2008 | Computers & Internet
CPU fan
When you say power is going to the mobo, are
other fans and lights turning on? You also may have forgotten to plug in
the large ATX power cord from the PSU, or the smaller 4-pin rectangular 12V
power cord. Is the correct local voltage setting for your PSU selected (110
or 220)?
Feb 19, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
New processor
Usually you can use Northwood-core CPU-s on mobos with Willamatte-core CPU. But is important (exept core) - FSB support of your new processor. Which model of your CPU? What the mainboard use (model)?
Nov 15, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel D845GVSR Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
