Question about Linksys Wireless-G WRT54G Router
Followed setup instructions on CD. Had all lights on on both the modem and the router (WRT54G): power, cables, internet, activity, etc. Even the little lights on the ethernet cable connected to the computer were blinking, indicating Internet connection. But kept getting "cannot find Internet connection" message. Tried several times. Please help!!!
  • Linksys Master
  • 7,733 Answers
Where can i buy setup disc
Router setup
You do not have to use the cd.
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
Aug 07, 2012 | Linksys Wireless-G WRT54G Router
It has stopped connecting to the Internet. The cable modem and computer are fine, but the cable modem and the linksys no longer "talk" to each other. Other wireless connections in my vicinity work OK on...
Base from the description of your problem it seems that we need to reconfigure the router to work with your modem again and we need to do that manually using a computer connected wired to the router.
To do that follow these steps.
Connect the modem to the router and computer to router also, make sure all connections are correct.
Then power on the router , modem and computer and check all the lights on the router are fine and make sure power is solid green if those are fine access the router setup page.
From the computer that is wired to the router a\open internet explorer and type 192.168.1.1 and hit enter then that should ask for a username and password, just leave the user name blank and password is admin hit enter you should be now on the router page.
From there under SETUP tab look for a sub tab MAC ADDRESS CLONE , then enable that and clcik on clone pc mac and ten save settings and once its save power off the router and modem for 1 minute then after that power on the modem and then the router and check if internet is already working.
Oct 11, 2010 | Linksys Wireless-G WRT54G Router
Cable modem internet works when directly plugged into desktop, but when run through the router, no connectivity
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform five steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the Router's LEDs
  4. Configuring a Linksys Router for a Cable Connection
  5. Power Cycling
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
kb4682-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports. For instructions, click here.
After connecting the devices, check the LEDs by following the instructions below.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
After checking the router's LEDs, configure the router for cable Internet. For instructions, follow the steps below.
kb4682-002_en.png For Telstra Cable internet users, please contact Telstra to confirm if your internet connection is using DHCP or HB (Heart Beat) signal. There should be no other machine running HB client upon doing this procedure.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE
: If you are using Mac to access the router's web-based setup page, click here. If you forgot your IP address, click here. If you forgot your router's password, click here.
Step 2:
When the router's web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select Automatic Configuration - DHCP.
(a) If you are NOT using Telstra HB, proceed with DHCP setup.
NOTE: If you are a Telstra Cable internet user and you're using WRT120N, WRT160N v1, WRT320N or WRT610N, please select Telstra Cable.
(b) If you are using Telstra Cable, proceed with the following setup. Obtain your user name and password from Telstra. Please disable any HB client that might have been previously running on the PC after the router is configured.
Step 3:
Click kb4682-005_en.png.
Step 4:
Click MAC Address Clone.
Step 5:
Select Enabled and click Clone My PC's MAC.
Step 6:
Click kb4682-012_en.png.
Step 7:
Click Status. Check the value of the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem. For instructions, click here.
NOTE:
If the Internet IP Address is all zeroes (0.0.0.0) click kb4682-008_en.png first then click kb4682-009_en.png. If the Internet IP Address is still all zeroes (0.0.0.0) perform a power cycle. For instructions, click here.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment. For instructions, click here.
Once the router is configured, perform a power cycle. For instructions, follow the steps below.
Power Cycling
Step 1:
Shutdown the computer.
Step 2:
Unplug the router's power cable.
Step 3:
Unplug the Broadband modem's power cable and wait for 30 seconds.
Step 4:
Plug in the Broadband modem's power cable and wait for its lights to appear stable.
Step 5:
Plug in the router's power cable once the modem's lights appear stable.
Step 6:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router.
Sep 28, 2010 | Linksys Wireless-G WRT54G Router
Initial Wireless Router connection problem.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
If your computer is able to go online
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | Belkin Computers & Internet
How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Jan 10, 2010 | Linksys Wireless-G WRT54G Router
No more internet thru router after new modem installed
Router setup
Go to the control panel and un-install the program that the Comcast cd installed. then:
Did Comcast reset you wireless router settings? If so, you may need to set up your SSID and security settings.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 05, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless G CD will not install
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed.
then:
Connect the Cat5 cable from the modem to the WAN port on the router. Then connect a Cat5 cable from any port on the router to your PC's network port.
Thanks, Joe
Nov 27, 2008 | Linksys Wireless-G WRT54G Router
I bought a Linksys wireless G-WRT54G Router. When I purchases it I was told this was all I needed and how easy it was to set up. I have no idea what I am doing but I can not get it to work. I have a...
Other than the laptop and the LinkSys WRT54G, you would need an active account/subscription with an Internet Service Provider (ISP) who then will provide you with a modem of sort.
On initial setup, connect your modem to your laptop and verify that you can connect to the Internet. Thereafter run the CD installer that came with the LinkSys before connecting/powering the LinkSys. Follow on screen instruction. At one point in the installation, you would be asked to disconnect the modem, connect the router and connect the modem to the router.
Should for some reason the above instruction will not address your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Linksys Wireless-G WRT54G Router
Lost setup dvd
Don't worry about the lost cd. Router will still work even without the setup disc. What is the model # of your router? What is your internet provider, Cable or DSL? For cable ISP, you'll just need to connect the Cable Modem to the Internet port on the back of the router, and your PC connect it to port number 1 on the router as well. Now try to power cycle all devices by unplugging the power to the router and the modem. Wait for 30 secs. Power on the cable modem first and wait for the lights to go steady then power on the router. Check if the internet works fine. If you're on DSL, you can do the same steps first. Otherwise, post your feedback.
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
Wrt54g
To setup your router manually click here
Dec 17, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
88 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
