The best dvd recorder to with my dvr
I am looking to buy a dvd recorder so i can record from my dvr. what schould i be looking for in a dvd recorder?
  • 35 Answers
Hi evguess,few things to look in your dvdr is that it should record major formats.it should have a FireWire connection for DV camcorder hookup.and relatively painless operation and ofcourse sould have all the spares avalable on your local market.
ive got a few options the best available dvdr.
1)philips dvdr80.
2)lite-on LVW-5005
3)DMR E50K (THIS MODEL DOES NOT HAVE A FIREWIRE BUT ITS THE LEAST EXPENSIVE MODEL.
hope this help to reach your requirement.
plz rate it if this review helps u.thanks..
Posted on May 11, 2008
How do I connect my network recorder to my outdoor network camera's ?
Most security DVR's come with software that control the cameras. Most DVR's use BNC type connectors and unless you buy a wireless system, you will have to run cables for them.
Aug 17, 2014 | Computers & Internet
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Power off after recording
Hi All,
This is a power supply problem.... the MR2920 stanby IC miss behaved, it power off and fail to power back on.
Solution, get pioneer power supply replacement or take the dvd recorder to your local electronic service repair to take a look at the power supply circuit.
Best of luck
Kenny
Apr 21, 2009 | Pioneer DVR-520H DVD Recorder
Trying to record from TV.
TRY HOOKING THE COAX TO THE DVD RECORDER THEN TO THE TV ,BEST I COULD THINK OF.
Mar 27, 2009 | Cyberhome DVR 1600 DVD Recorder
Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Feb 12, 2009 | Sony VRD-MC5 DVD Recorder
How do i connect dvr to dvd to tv?
I assume the dvd is a player/recorder. So the dvd and dvr are both recording devices. You can take the outputs of cable box into the inputs of dvr. Then the outputs of dvr into inputs of dvd. Outputs of dvd into tv. It will be combersum to use that way but it will work. I would have to know what you were trying to accomplish to recomment the best setup.
Jan 16, 2009 | Televison & Video
Change all the caps in power supply
Hi, my cyber home 1600 has all kind of problems as in posting, I won't buy any products make from Cyberhome from now on, Also don't buy any things from Best buy Store because I bought my 1600 from Best buy store.
Aug 19, 2008 | Cyberhome DVR 1600 DVD Recorder
Record DVDs frrom Cable box DVR
Buy a recorder that records both +/-R and double layer disks.
I haven't seen a Comcast dvr but you should connect it to the svideo out port of the dvr to the svideo in of the recorder and the audio out to the audio in. If the Comcast doesn't have svideo use the video ports instead
Dec 20, 2007 | Cyberhome DVD Recorder - DVR1600
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
