Question about Whirlpool Duet GHW9150P Front Load Washer
Have a whirlpool duet model GHW9400PLO. Husband put a rug in it and now it shows an F2 error and will not drain. We have tried unplugging the machine, that has worked in the past, but this isn't fixing it.
    Scholar:
  • 91 Answers
Hi dear.According to your explanation,it's drain problem(F2 code).Please get access machine filter.Check it for any obstacle(Rug Fluff etc...)clean it & run the machine.It should get back to normal.Also check for any kink in drain hose.If that does not work you may need to replace the pump.I hope that helps.Thanks.
Posted on Sep 03, 2010
What does the Code E1 mean for a Whirlpool Duet washer?
There is a small access panel on the bottom of these newer Maytag and Whirlpool washers. Three small quarter inch screws hold the panel in place.
Once the screws are removed the panel will come off. The pump filter is directly in front of you at this point. The handle can be twisted counter clock wise and then pulled out. Most likely you will find some sort of debris inside. It can be an article of clothing, lint, backing from a rug, or change
Sep 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F2 code for Whirlpool duet washer
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load washer display shows f2
some of these models f-02 means clogged drain. check pump
Feb 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9400PLO
The "Fdl" code is a Door Latch Lock error. Inspect the door latch for obstructions that may be preventing it from locking and doublecheck the wire harness to ensure all the connectors are intact. If the latch is defective, use the following link for advice on how to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Another method of replacing the latch is to remove the top panel and work form the top down behind the front panel. Due to limited space, this may not be desireable to some.
Replacement latches can be purchased on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for your search criteria. These sites have great service and offer competitive pricing. Check out all three for the best savings.
I hope this information helps you. Let me know if you need further assistance.
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine shows a F2 error and won't finish washing my clothes. I tried pushing the button for 5 seconds, but nothing happens. I even unplug the machine from the wall. What do I need to do?
F 02, is a "long drain" error. So perhaps there is a clog in your pump assemble. reomve the 3 screws from along the front bottom of your machine(3 torx 20 screws) youll seee the acees cover to your pump behind there.
Dec 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door Lock does not lock
1 o 2 issues either a bad door lock, or the machine control board located under the main top is malfunctioning.
Feb 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
208 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
