Question about Fujitsu M4099D/FI-4990C Scanners
Fujitsu M4990C I am getting the "Frontside background changeover function overrun" error, the same one mentioned in a previous issue. I have replaced the frontside changeover solenoid and sensor. Unfortunatly still getting this error. During further testing the scanner now hangs before scanning the first page. The hopper raises and right before in normally starts feeding pages the hopper drops half way down and the scanner hangs with "Scanning" on the LCD panel. It does this in test mode disconnected from the PC as well. Any ideas or recommendations on this would be appreciated? Thank you..
jackboy
  • 2985 Answers
SOURCE: Fujitsu 5210c Scanner
Uninstall the scanner software and also the program you use to access the scanner Restart the computer and reload the software[s] Or first try a system restore.
Posted on Jun 25, 2007
remt23c
  • 78 Answers
SOURCE: Out of paper :CDT009 Load mroe paper to continue scanning
on the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Posted on Oct 15, 2007
SOURCE: Scanning speed slowed...
did you change your scan resoulution? The quality of your scans will determine how slow it will pass through. another thing to check is weather it is scanning both sides, another option in your scanner properties.
Posted on Jul 23, 2008
SOURCE: TWAIN Driver Error
If the windows image acquisition service is running, stop/disable it and see if this helps with the apparent concurrency problem.
Posted on Apr 16, 2010
TechSatya
  • 104 Answers
SOURCE: the fujitsu fi-5110C won't scan all pages just
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Posted on Jul 19, 2010
Code EF 5120c
"EF error" in Fujitsu fi-5120c scanner refers to Background changeover unit failure. This error is detected in initial checking at power on.
Probable causes:
- Defective Control PCA
- Insulation material damage of BW motor cable or the damage of the wire in the motor.
Check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2.Are the cables between the Control PCA and the BW motor damaged? Or are the connectors connected correctly? Confirm the position of the BW motor and check the cables.
3.Is the CCD cable F or B damaged? Or are the connectors connected correctly?
If the above information doesn't help, then you are recommended to visit the nearest Fujitsu service center for assistance.
Thanks & regards,
ScanCare
Mar 03, 2014 | Fujitsu fi-5750C Flatbed Scanner
Error EF
The error code EF displayed on your fi-5750c scanner front panel explains Background switching mechanism alarm. The probable causes are:- Background detection sensor connector disconnected.
- Defective background detection sensor
- BW motor connector disconnected, Defective BW motor
- Defective background unit F
- Defective background unit B
You are rceommended to visit nearest Fujitsu service station for rectification.
Thanks & regards,
ScanCare
Nov 07, 2013 | Fujitsu fi-5750C Flatbed Scanner
I receive an error F4 on my scanner when I turn it on. Will not scan. Any suggestions?
Hello Larry,
The F-4 error in Fujitsu fi-6240 scanner indicates Background change over unit malfunction alarm. It may be caused by the malfunction of background motor or optical unit or damaged optical cable.
You are recommended to contact the nearest Fujitsu scanner service center for rectification.
Thanks & regards,
ScanCare
Sep 25, 2013 | Fujitsu Fi-6240 Flatbed Scanner
Fujitsu Fn key stuck laptop PC Laptops
The Function keys can be usually disabled by a manufacturer provided program, in the control panel.
You can also probably download a replacement from Fujitsu.
Fujitsu America Support
If it is a hardware problem, it should be coming up as a keyboard error on start up, it will not say which key is stuck, so this is probably a software issue.
The manual is listed below for the function key use.
http://solutions.us.fujitsu.com/www/content/pdf/usermanuals/sseries/S7010,S7010D_ONION_USERGUIDE.PDF
Dec 12, 2012 | Fujitsu Siemens LifeBook S7010 Notebook
Fujitsu 6130 background switching mechanism error
Hi how do you fix Fujitsu 6130 F4 error? Thanks
Mar 20, 2012 | Fujitsu fi-6130 Flatbed Scanner
AN ERROR "F" AND "4"
Hi,This error is Background switchover alarm. Check the background change over mechanism drive and BW motor functioning or not? Cleaning the mechanism may resolve the issue.
regards,Scancare
Jan 12, 2011 | Fujitsu fi-6770 Flatbed Scanner
Background changeover unit failure [fi-5120Cdj #2 , 048005 , c2]
Hi Vivek,
Thank you for contacting Fixya.
When a background switching malfunction occurs, "E" and "F" will display alternately on the function number display panel of the scanner.
Background changeover unit failure error is detected in initial checking at power on. Probable causes:
- Insulation material damage of BW motor cable or the damage of the wire in the motor. - Defective lamp or CCD or CCD cables. - CCD Connector disconnected. - Defective Control PCA.
Solution:
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 (or isopropyl alcohol) and check if the problem persists.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON. 2. Check if the cables between the Control PCA and the BW motor damaged? Are the connectors connected correctly? Check & confirm the position of the BW motor and check the cables. 3. Check Is the CCD cable F or B damaged? Or are the connectors connected correctly? 4. Check if the OPT Unit is installed correctly? 5. Check if the white reference works properly? If not, then replace the BW Motor. 6. If the above do not resolve your issue, then you may have to replace the Control PCA or Optical unit to see if the error is resolved.
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Aug 18, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Background changeover unit failure on 6130dj scanner. Tried cleaning it, rebooting pc & downloading driver . . . what else can I do?
When a background switching malfunction occurs, "F" and "4" will display alternately on the function number display panel of the scanner.
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 and check if the problem persists.
If turning on the scanner again does not recover the situation, then follow the procedures provided below:
1 Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2 Are the cables between the Control PCA and the BW Motor damaged? Or are the connectors connected correctly?
3 Is the white reference work properly? If not, then replace the BW Motor.Perform background changeover test.
4 Is the OPT Unit installed correctly? Check ADF (Front) and ADF (Back)
5 Replace the Control PCA and see if the error is resolved.
6 Replace the OPT Unit and see if the error is resolved.
Thanks,
ScanCare
Apr 26, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Fi4990C
When the scanner scans the first image it will bring in via a set of solenoids a background white Reference metal flap for both rear and front cameras.
The above error comes about when the solenoids are sticking or they have magnetised themselves.
1.Clean the Solenoids.
if scanner still errors .
2. Replace solenoids.
Dec 30, 2008 | Fujitsu M4099D/FI-4990C Scanners
Fujitsu 4860c scanner error
There are 2 sensors on the background unit(Front) SF1.5 and SF 2
Both sensors look like black boxes. SF2 is nearest the reading glass and SF1.5 is below it. Make sure both are clean. There are also tests you can run in test mode to recalibrate the sensors, if that doesn't work you have to replace it.
Apr 24, 2008 | Fujitsu FI-4860C2
115 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
