Question about Canon PIXMA MP600 all-In-One InkJet Printer
The magenta won't work. i put a new cartridge, cleaned headers, test printed. all the other colors work find but, NO magenta comes out.
    President:
  • 1,335 Answers
This sounds like you are using an aftermarket or refilled ink cartridge. If this is the case, try putting in a new OEM magenta ink cartridge and running the deep cleaning utility 3 times. This usually clears a clogged nozzle caused by non-OEM loaded inks.
Let me know if this clears the problem. Thanks.
Posted on Sep 03, 2010
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Photos are coming out Orange
Clean your print head under the ink maintenance / cleaning. Then test print. All your colors should pass this test. Your magenta is not complete.
Nov 21, 2013 | Brother DCPJ315W AllInOne Inkjet Printer
PRINTER (not web camera!) HP Deskjet 712c Printer began printing mostly blackPrinter began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black...
First run the CLEAN HEADS and see if that helps. If you don't use your printer at least once a week the Print Heads get dried out and will not allow the ink to pass through to the paper.
Go to control Panel and click on Printess. Then when the window comes up, CLICK on Properties TAB and then in the next window, CLICK on CLEANING.
You may have to replace your PRINT HEAD if that doesn't work.
Hope this is of some help. Bud
Feb 06, 2010 | Computers & Internet
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Hp deskjet F4180 prints wrong colour blue header prints in magenta only,new inks installed,nozzles cleaned,test page prints ok
I had the same problem and the solution I found was to uninstall and then reinstall the printer driver. For some reason this worked. I now get the correct colors.
Jul 11, 2008 | Office Equipment & Supplies
First of all clean the contacts in the printer for the magenta cartridge, if there is no improvement replace the magenta cartridge, if that doesn't work come back to me
Jun 12, 2008 | HP Color LaserJet 2600n Printer
Printing color copies
check to see which cartridge you put in, photo magenta cartridges DO NOT work in the MP830. sounds silly but we see it all the time.
check to see if the short vertical black bar next to the magenta pattern looks ok, not brown or gray or streaky. if it is you may need a professional head flush, take the whole printer in for service.
Jun 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
Color problems with Lexmark X75 printer
hi ..
please get new color cartridge tested with other Ok printer
then from your printer get cartridge alignment with clean cartridge utility
Apr 08, 2008 | Lexmark X75 All-In-One InkJet Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
229 people viewed this question
old marine
old marine
